Usb connection and PIC18F4550
Goto page Previous  1, 2
Ken Johnson
PostPosted: Thu Sep 27, 2007 6:52 am     Reply with quote
Another plug for a demo board - I recently went through this myself, using the demo from Microchip (all of $60, I think). It has an rs232 port on it, which you can connect to a pc (e.g. hyperterm) and be assured that the pic is running. It outputs a message when it starts up, when the usb cable is connected (looks at the power supply pins) - very helpful.
Note: in the usb example code, you'll need to "un-comment" a line, I think line 76, #define USB_CON_SENSE_PIN PIN_B2, but don't remember for sure.
good luck,
Ken
wwc
PostPosted: Fri Sep 28, 2007 7:39 am     Reply with quote
ELCouz wrote:
Should come with you CCS Compiler if not...
get it right there -->18f4550.h Wink
Thank you so much!!
ELCouz
PostPosted: Fri Sep 28, 2007 8:05 am     Reply with quote
no problem and please don't copy/paste the same post its useless and annoying...
----> Right Here <----
Page 2 of 2
