RS-232 Woes
wrocko
View user's profile Send private message Visit poster's website AIM Address MSN Messenger ICQ Number
RS-232 Woes
PostPosted: Sun Sep 28, 2003 1:03 pm     Reply with quote
I am a bit new to PCW and MCUs in general. I am trying to get some RS-232 communication going between two chips (16f877), more or less as practice. Yet, I am encountering two main problems: my receiving code and my sending code Embarassed . Alright, for my receiving code, I am having the program wait for a byte to arrive and then when one arrives, it just toggles an output so i know it worked. Yet, regardless of what I hook the RX pin to, my designated output pin toggles more or less at the speed of my main loop (very fast). The code is as follows:
#include <16F877.h>
#fuses XT,NOWDT
#use rs232(baud=9600,parity=N,xmit=PIN_C6,rcv=PIN_C7, ERRORS)
#include "C:\Documents and Settings\Admin Bin\My Documents\ECE497\Code\rs232test.h"
int toggle = 0;
int i = 0;
setup_adc_ports(NO_ANALOGS);
setup_adc(ADC_CLOCK_DIV_2);
setup_spi(FALSE);
setup_counters(RTCC_INTERNAL,RTCC_DIV_2);
setup_timer_1(T1_DISABLED);
setup_psp(PSP_DISABLED);
setup_ccp1(CCP_OFF);
setup_ccp2(CCP_OFF);
set_tris_a(0x00);
output_a(0x00);
for(;;)
if(kbhit())
if(toggle==0){toggle = 1; output_low(PIN_A0);}
if(toggle==1){toggle = 0; output_high(PIN_A0);}
delay_us(10);
My only problem with transmitting is that I don't know how to tell if it is working at all since I can't receive it Confused. Here is the sending code though:
#include <16F877.h>
#fuses XT,NOWDT
#use rs232(baud=9600,parity=N,xmit=PIN_C6,rcv=PIN_C7)
#include "C:\Documents and Settings\Admin Bin\My Documents\ECE497\Code\controlsystem.h"
setup_spi(FALSE);
set_tris_a(0x00);
output_a(0xAA);
// Main Loop
for(;;)
putc("a");
delay_ms(10);
putc("b");
delay_ms(10);
putc("c");
delay_ms(10);
Any help would be greatly appreciated.
-- Wrocko --
PostPosted: Sun Sep 28, 2003 2:13 pm     Reply with quote
// Main Loop
for(;;)
putc("a");
delay_ms(10);
putc("b");
delay_ms(10);
putc("c");
delay_ms(10);
I wonder what version of the compiler you're using ?
Because, with a late version of the compiler (PCM vs. 3.176),
it gives the error: "A numeric expression must appear here",
when you use a quoted string with putc().
So as an experiment, I compiled it with PCM vs. 2.734.
Result: No errors, but no code produced for those lines, at all.
So, I conclude that you're using an early version of the compiler.
You need to change the double quotes to be single quotes.
Like this:
putc('a');
putc('b');
putc('c');
wrocko
PostPosted: Sun Sep 28, 2003 8:51 pm     Reply with quote
Thanks, that did the trick for the transmitter. I solved my own problems on the receiver. I wasn't emptying the characters that came with getc() so the loop kept going into the toggle area. The toggle was messed up too but that is just icing on the cake. Im all set now, thanks again. Very Happy
-- Wrocko --
