How to transmit characters/special characters over SPI?
Jeetdesai
PostPosted: Tue Jul 10, 2018 8:44 am     Reply with quote
I can successfully transmit decimal, hex and binary data over SPI. I check my signals by connecting the oscilloscope probes at the data out, clock and enable pins, and observe the waveforms.
But i'm getting the wrong data when I send characters(A, B ... Z)) or special characters(!, @ ... +). The waveform on the output is the same (01100111) for all alphabetic characters and special characters.
The following is my code:
#include <18F87K22.h>
#FUSES INTRC_IO                  //Internal RC Osc, no CLKOUT
//#FUSES NOPUT                     //No Power Up Timer
#FUSES NOPROTECT                 //No code protected from reads
#FUSES MCLR                      //Master Clear pin enabled
#FUSES NOCPD                     //No EE protection
#FUSES NOBROWNOUT                //No brownout reset
//#FUSES BROWNOUT                  // Hold in reset during brownout - else can corrupt EEPROM, act strange, etc
#FUSES NOIESO                    //Internal External Switch Over mode disabled
#FUSES NOFCMEN                   //Fail-safe clock monitor disabled
#use delay(clock = 1000000)
#define CS Pin_H0
//#BYTE ODCON1=
//#BIT  ODCON1BIT7 = ODCON1.7
/*#define SPI_MODE_0  (SPI_L_TO_H | SPI_XMIT_L_TO_H)
#define SPI_MODE_1  (SPI_L_TO_H)
#define SPI_MODE_2  (SPI_H_TO_L)
#define SPI_MODE_3  (SPI_H_TO_L | SPI_XMIT_L_TO_H) */
setup_spi(SPI_MASTER | SPI_H_TO_L| SPI_CLK_DIV_64);
   output_low(CS);
   //spi_write(0x55); //hex data
   //spi_write(75); // decimal
   //spi_write(0b11110000); // binary
   spi_write("A"); //Char data
   output_high(CS);
   delay_us(1000);
PostPosted: Tue Jul 10, 2018 9:34 am     Reply with quote
This is not the correct way to do it.
The correct way is to use single quotes:
spi_write('A');
Jeetdesai
PostPosted: Tue Jul 10, 2018 9:46 am     Reply with quote
Thanks You so much !!!
