adc [Solved]
Goto page Previous  1, 2
PostPosted: Sun Mar 04, 2018 9:27 am     Reply with quote
I must admit I was assuming he was using his original code. The new code as you say has introduced a whole handful of new idiocy.... Sad
PostPosted: Sun Mar 04, 2018 12:30 pm     Reply with quote
what should be done is a SIMPLE 5 line program to test the adc.
main()
start:
..select an adc iput
..read that input
..send data to PC
..delay for 1 second
..loop back to start:
This needs to be done BEFORE any 'fancy' program is tried.
Jay
NAVID
PostPosted: Tue Mar 06, 2018 8:45 am     Reply with quote
Ttelmah wrote:
OK. I'd say that the error is just a fault with Proteus.
I've seen exactly the same on another chip, where the acquisition time is hardware programmable, and was set to MicroChip's recommendations, directly from the data sheet, yet Proteus perpetually complained about inadequate acquisition time.
This is a typical example of the sort of problem that Proteus has.....
However this does assume you have set the clock in Proteus that the simulation is using to 20MHz.
hi tnx for helping...but its not working correctly in real hardware....
PostPosted: Tue Mar 06, 2018 8:49 am     Reply with quote
What is the problem when you run real hardware ?
You have never told us.
You told us the problem with Proteus is the error message:
"ADC conversion started before 'wait' time has expired following previous
conversion or channel change."
But real hardware won't give that message.
NAVID
PostPosted: Tue Mar 06, 2018 9:04 am     Reply with quote
i dont know how to explain!!
the problem is when i change adc input its not change on lcd
and some time (mostly) its like the micro is locked...
i write the code to show me power up time (sec2) but its not changing...
but i put led for flashing every second and its flashing correctly!!!
im confused....
PostPosted: Tue Mar 06, 2018 11:02 am     Reply with quote
please post your current program...
maybe we can see the error.
NAVID
PostPosted: Tue Mar 06, 2018 2:40 pm     Reply with quote
sure...tnx for help
#include <main2.h>
#include "lcd_flex.c"
unsigned int8 period,puls_forward=0,puls_back,step;
unsigned int16 sec2;
unsigned  int32 left=0,right=0;
 // int16 a0,a1;
#INT_RTCC
void  RTCC_isr(void)  //for 1 sec
if(period==100){
period=0;
//sec++;
sec2++;
output_toggle(pin_a5); // led for test
else period++;
set_timer0(60);
#INT_TIMER1
void  TIMER1_isr(void)
   setup_adc_ports(AN0_AN1_AN3);
   setup_adc(ADC_CLOCK_DIV_64);
 //  setup_adc(ADC_CLOCK_INTERNAL);
   setup_timer_0(RTCC_INTERNAL|RTCC_DIV_256|RTCC_8_bit);      //13.1 ms overflow
   setup_timer_1(T1_EXTERNAL|T1_DIV_BY_1);      //13.1 ms overflow
   enable_interrupts(INT_RTCC);
   int16 a0,a1;
   set_timer1(0);
   delay_ms(1);
    set_adc_channel(0);   //
    delay_ms(10);         //
    a0=read_adc();        //  i have problem here
    set_adc_channel(1);   //
    delay_ms(10);         //
    a1=read_adc();        //
   lcd_clear();
   lcd_gotoxy(1,1);
   printf(lcd_putc,"%d   %lu   %d   ",period,sec2,puls_forward);
   puls_forward=get_timer1();
   lcd_gotoxy(1,2);
   printf(lcd_putc,"%lu     %lu   ",a0,a1);
   ///////////////////////////////////////////////////////////// forward
    if(a0>500 && a1>500){
     if(sec2==570){
       for(step=0;step<30;step++){
       if(a0+20>a1){output_high(pin_d0); //left
                    output_low(pin_d1);
                    left++;}
       if(a1+20>a0){output_high(pin_d1); //right
                   output_low(pin_d0);}
                   right++;   }
       step=0;
       sec2=0;
    /////////////////////////////////////////////////////////// back
     else{
    output_low(pin_d0);
    output_low(pin_d1);
    set_timer1(0);
    do{
    if(right>left){output_high(pin_d0); //left
                   output_low(pin_d1);}
    if(right<left){output_high(pin_d1); //right
    puls_back=get_timer1();
    }while(puls_back <= puls_forward);
    if(puls_back == puls_forward){
    left=0;
    right=0;
    set_timer1(0);
    puls_back =0;
    puls_forward=0;}
      //TODO: User Code
and its .h:
#include <16F877A.h>
#device ADC=10
#use delay(crystal=20000000)
also i tried on Difference delay and Difference ADC clock source.
PostPosted: Tue Mar 06, 2018 3:48 pm     Reply with quote
I'd try something like this....
   int16 a0,a1;
   delay_ms(500); ///hardware delay to be sure LCD module is running
    delay_ms(1);         /// smaller delay !
    a1=read_adc();        //
    lcd_clear();
    lcd_gotoxy(1,2);
    delay_ms(1000); // delay for 1 second, so main 'loops' at 1hz rate
Notice I've deleted EVERYTHING except 'read the adc and display results'
Also why bother with the 'header' ? Those 3 lines of code could be at the top of your program.
There may be a typo but it should work.
Jay
NAVID
PostPosted: Wed Mar 07, 2018 8:56 am     Reply with quote
   int16 a0,a1;
    a1=read_adc();        //
    lcd_clear();
    lcd_gotoxy(1,2);
Jay
ok tnx....i check it and notify the results
NAVID
PostPosted: Fri Mar 09, 2018 2:45 am     Reply with quote
hi...i solved it!!!
the adc was work correctly when i increased the delay...but its not showed on lcd!!
so i wrote a function named "display" and call it every where in program to
refresh led every time... and its work correctly in simulation and real hardware...tnx everyone for help (:
this is my final code:
#include <main2.h>
unsigned int16 sec2=0;
int16 a0,a1;
void display(void);
 // int16 a0,a1;
#INT_RTCC
if(period==100){
period=0;
//sec++;
sec2++;
else period++;
set_timer0(60);
#INT_TIMER1
   set_timer0(0);
   set_timer1(0);
   delay_ms(1);
    set_adc_channel(0);
    delay_us(300);
    a0=read_adc();
    set_adc_channel(1);
    delay_us(300);
    a1=read_adc();
    display();
     if(sec2==570){
                    output_low(pin_d1);
                    left++;
                    display();}
                   right++;
                   display();}
       step=0;
       sec2=0;
     else{
     display();
    output_low(pin_d0);
    output_low(pin_d1);
    set_timer1(0);
    do{
     display();
    left=0;
    right=0;
    set_timer1(0);
    puls_back =0;
    puls_forward=0;
     display();}
      //TODO: User Code
void display(void){
  set_adc_channel(0);
    delay_us(30);
    a0=read_adc();
    set_adc_channel(1);
    delay_us(30);
    a1=read_adc();
   lcd_gotoxy(1,1);
   lcd_gotoxy(1,2);
Page 2 of 2
