PIC 16F877
Ashish
PIC 16F877
PostPosted: Tue Jul 22, 2003 1:10 pm     Reply with quote
I am using PIC C in SPI Mode,
When ever i am communicating on SPI bus, the Variables are getting set to 85 .(like Sequence = 85);
This is very strange problem, i have come across.
Original Post ID: 144516252
Re: PIC 16F877
PostPosted: Tue Jul 22, 2003 2:16 pm     Reply with quote
:=I am using PIC C in SPI Mode,
:=When ever i am communicating on SPI bus, the Variables are getting set to 85 .(like Sequence = 85);
:=This is very strange problem, i have come across.
Post a very small, but complete, program that shows the problem.
Also give the version of your compiler.
Original Post ID: 144516259
Pete Smith
Re: PIC 16F877
PostPosted: Wed Jul 23, 2003 2:47 am     Reply with quote
Hi.
Do you have a short on your board? 85 = 01010101 which looks very much like the SPI clock sigal.
Pete.
Original Post ID: 144516279
Ashish
PIC 16F877
PostPosted: Wed Jul 23, 2003 9:21 am     Reply with quote
The problem is,
i am not receiving any bad input from SPI Bus,
if i start the SPI communcation, The variable in the PIC is loaded with 85.
I am not even sending the variable over SPI bus, I tested it on different boards, problem remains same.
Original Post ID: 144516285
Re: PIC 16F877
PostPosted: Wed Jul 23, 2003 1:02 pm     Reply with quote
:=The problem is,
:=i am not receiving any bad input from SPI Bus,
:=if i start the SPI communcation, The variable in the PIC is loaded with 85.
:=I am not even sending the variable over SPI bus, I tested it on different boards, problem remains same.
Well, if you posted a small program that demonstrates your
problem, then we could see what you are doing, and maybe
offer some help.
Original Post ID: 144516294
