16f877 STATUS register
mle
PostPosted: Fri Jul 18, 2003 8:41 am     Reply with quote
Why are there four different status registers and how do I know which one to check?
Thanks,
mle
Original Post ID: 144516145
Charlie U
Re: 16f877 STATUS register
PostPosted: Fri Jul 18, 2003 9:59 am     Reply with quote
:=Hello,
:=Why are there four different status registers and how do I know which one to check?
:=Thanks,
:=mle
There is only one Status register, but it is accessible in all 4 banks. Within a C program, use #byte STATUS = 0x03 to declare the Status register and then access is as you would any other variable (int). You do not need to deal with bank switching, the compiler will handle that.
Original Post ID: 144516150
mle
great thanks!
PostPosted: Fri Jul 18, 2003 10:06 am     Reply with quote
:=:=Hello,
:=:=Why are there four different status registers and how do I know which one to check?
:=:=Thanks,
:=:=mle
:=There is only one Status register, but it is accessible in all 4 banks. Within a C program, use #byte STATUS = 0x03 to declare the Status register and then access is as you would any other variable (int). You do not need to deal with bank switching, the compiler will handle that.
Original Post ID: 144516151
