Pointer to string problem
proggy
PostPosted: Mon Jul 14, 2003 12:00 pm     Reply with quote
I'm trying to pass a string to my LCDPrint function. LCDPrint should print the offsetted characters (string) to the LCD screen, but it doesn't work. Can anyone explain why this does not work with the CCS compiler or if there is another way around this?
void LCDPrint(char *pch)
while(*pch)
AutoOut(*pch - 0x20); //output offset character
pch++; //point to next character
I'm using version 3.168.
Original Post ID: 144515961
Re: Pointer to string problem
PostPosted: Mon Jul 14, 2003 12:56 pm     Reply with quote
:=I'm trying to pass a string to my LCDPrint function. LCDPrint should print the offsetted characters (string) to the LCD screen, but it doesn't work. Can anyone explain why this does not work with the CCS compiler or if there is another way around this?
:=void LCDPrint(char *pch)
:= while(*pch)
:= AutoOut(*pch - 0x20); //output offset character
:= pch++; //point to next character
:=I'm using version 3.168.
I don't have an LCD on my test board, currently, so I
just directed the output to putc() instead, but this
test program worked OK with PCM vs. 3.168.
Because you're subtracting 0x20 from each char, I had
to use lower case chars and the @ symbol, in order to
get some readable output on my terminal window.
It displays: "HELLO WORLD"
#include "c:\Program Files\Picc\Devices\16F877.H"
#use delay(clock = 8000000)
#use rs232(baud = 9600, xmit=PIN_C6, rcv = PIN_C7, ERRORS)
void LCDPrint(char *pch);
void AutoOut(char value);
char buffer[20];
strcpy(buffer, "hello@world");
LCDPrint(buffer);
while(*pch)
putc(value);
Original Post ID: 144515965
proggy
PostPosted: Mon Jul 14, 2003 1:46 pm     Reply with quote
Instead of copying the string into buffer, couldn't you use the function itself?
For example:
LCDPrint("testing display");
:=I don't have an LCD on my test board, currently, so I
:=just directed the output to putc() instead, but this
:=test program worked OK with PCM vs. 3.168.
:=Because you're subtracting 0x20 from each char, I had
:=to use lower case chars and the @ symbol, in order to
:=get some readable output on my terminal window.
:=It displays: "HELLO WORLD"
:=#include "c:\Program Files\Picc\Devices\16F877.H"
:=#fuses HS, NOWDT, NOPROTECT, BROWNOUT, PUT, NOLVP
:=#use delay(clock = 8000000)
:=#use rs232(baud = 9600, xmit=PIN_C6, rcv = PIN_C7, ERRORS)
:=void LCDPrint(char *pch);
:=void AutoOut(char value);
:=void main()
:=char buffer[20];
:=strcpy(buffer, "hello@world");
:=LCDPrint(buffer);
:=while(1);
:= while(*pch)
:=putc(value);
Original Post ID: 144515968
PostPosted: Mon Jul 14, 2003 2:11 pm     Reply with quote
:=Instead of copying the string into buffer, couldn't you use the function itself?
:=For example:
:=LCDPrint("testing display");
No, because CCS doesn't support pointers to constant strings.
However, you can re-write your code to do it this way:
<PRE>
<BR>
void LCDPrint(char c);
<BR>
char const message1[] = {"hello@world"};
<BR>
<BR>
LCDPrint(message1);
<BR>
<BR>
<BR>
AutoOut(c - 0x20); //output offset character
<BR>
<BR>
putc(value);
</PRE>
Original Post ID: 144515971
