CAN bus and 18F248
Aryldo G Russo Jr
CAN bus and 18F248
PostPosted: Sun Jul 13, 2003 10:02 am     Reply with quote
Hi all,
Does anyone have any experience with CAN bus and 18F248?
I'm trying to implement this protocol, but I got stuck just after I have the configuration done.
I'm using CCS C 3.168, and I can see, using the watch windows, that after I send the configuration comand, it was accept correctly.
then, if I put my module in Loopback mode, I can see everything I send out in my receive buffer.
but if I put it in normal mode, I can't see anything at the scope, and the transmit error buffer has more than 255 errors, so my module goes to buf off mode.
any ideas?
Dinho
Original Post ID: 144515923
Douglas Richard
Re: CAN bus and 18F248
PostPosted: Mon Jul 14, 2003 5:05 am     Reply with quote
Do you have another working node connected to your set up?
:=Hi all,
:=Does anyone have any experience with CAN bus and 18F248?
:=I'm trying to implement this protocol, but I got stuck just after I have the configuration done.
:=I'm using CCS C 3.168, and I can see, using the watch windows, that after I send the configuration comand, it was accept correctly.
:=then, if I put my module in Loopback mode, I can see everything I send out in my receive buffer.
:=but if I put it in normal mode, I can't see anything at the scope, and the transmit error buffer has more than 255 errors, so my module goes to buf off mode.
:=any ideas?
:=Thanks
:=Dinho
Original Post ID: 144515940
Aryldo G Russo Jr
PostPosted: Mon Jul 14, 2003 5:12 am     Reply with quote
I'm developing my first node at this time. what I tried to do was create 2 nodes, with the same firmware(under development), but even though it's not working. is there any trick that I could use to test my CAN module alone?
what do I have to do to be able to see the wave form at he scope?
Dinho
Original Post ID: 144515941
Douglas Richard
PostPosted: Tue Jul 15, 2003 7:14 am     Reply with quote
Make sure you drive your outputs Hi (not tristate).
Original Post ID: 144515998
Mike Broom
PostPosted: Thu Jul 17, 2003 4:13 am     Reply with quote
:=I'm developing my first node at this time. what I tried to do was create 2 nodes, with the same firmware(under development), but even though it's not working. is there any trick that I could use to test my CAN module alone?
:=what do I have to do to be able to see the wave form at he scope?
:=Thanks
:=Dinho
if you are driving the output correctly, and thee bus is terminated then you should see the packets of data until the device bus off's
Original Post ID: 144516094
