how to avoid a/d channels affecting one-another ?
Darren Logan
PostPosted: Sun Jul 13, 2003 3:28 am     Reply with quote
Morning/afternoon/evening (depending on locale!),
PIC = 16F873
I'm reading all 5 channels of A/D but I am finding that different voltages on a channel may affect the results on another channel (by up to 50 bits!).
This is a most hideous situation which must be rectified!!!
I have tried adding filter caps (47nF) to inputs of a/d but this has no effect.
Anyone seen and beat this one, if so i'd like to hear from you!
Thanks in advance.
Regards,
Darren
Original Post ID: 144515920
R.J.Hamlett
Re: how to avoid a/d channels affecting one-another ?
PostPosted: Sun Jul 13, 2003 4:38 am     Reply with quote
:=Morning/afternoon/evening (depending on locale!),
:=PIC = 16F873
:=I'm reading all 5 channels of A/D but I am finding that different voltages on a channel may affect the results on another channel (by up to 50 bits!).
:=This is a most hideous situation which must be rectified!!!
:=I have tried adding filter caps (47nF) to inputs of a/d but this has no effect.
:=Anyone seen and beat this one, if so i'd like to hear from you!
:=Thanks in advance.
:=Regards,
:=Darren
The commonest cause of this, is not allowing enough time when switching channels.
The input to the AD converter has an internal capacitance, and if it is sitting looking at a 2v input, and is then switched to another channel with a 0.1v signal, will take time to charge to the new voltage. This time is dependant on the impedance of the sources driving the inputs, and the capacitance of the AD input (and on how 'close' the signal needs to get). If the time allowed is not long enough, then when the reading is taken, the pin may only be (say) 90\% charged to the new level, and the reading will be in error (in the case given, reading 0.29v), The value detected in each case, will depend on the voltage on the previous pin...
Original Post ID: 144515921
