mdemuth
Joined: 16 Apr 2007 Posts: 71 Location: Stuttgart, Germany
PIC16f15324 Pin A4 and Pin A5 not responding [solved] |
Posted: Tue Nov 22, 2022 5:57 am |
I am trying to get Pin A4 and Pin A5 working on PIC16f15324.
CCS Compiler Version: 5.103
My code:
#include <16f15324.h>
#fuses HS, NOCLKOUT, NOWDT,NOPROTECT,BROWNOUT,PUT,MCLR, BORV27
#use delay(clock=32000000)
#zero_ram
setup_oscillator (OSC_HFINTRC_32MHZ);
setup_adc_ports(NO_ANALOGS);
setup_adc(ADC_OFF);
while (1)
output_a(0xff);
output_c(0);
delay_ms(1);
output_a(0x00);
output_c(0xff);
delay_ms(1);
restart_wdt();
} // main ends
Port C toggles as expected.
Port A: Pin A0, Pin A1 and Pin A2 toggles as well.
But: Pin A4 and Pin A5 show no (re)action.
(I have tried 3 PCBs so I would exclude a hardware related problem.)
What could be the problem?
Michael
Posted: Tue Nov 22, 2022 6:29 am |
You are enabling the external oscillator (HS fuse). Probably what is causing
the problem. You don't need to use setup oscillator. Try:
#fuses NOEXTOSC,NOWDT,NOPROTECT,BROWNOUT,PUT,MCLR, BORV27
#use delay(internal=32MHz)
#zero_ram
setup_adc(ADC_OFF);
while (TRUE)
output_a(0xff);
output_c(0);
delay_ms(1);
output_a(0x00);
output_c(0xff);
delay_ms(1);
//restart_wdt(); //You haven't got the watchdog enabled.
} // main ends
Note the NOEXTOSC, and the changes to the clock settings.
as a comment, putting restart_wdt instructions inside code where they
can always be reached (if your watchdog was enabled), completely prevents
the watchdog from doing anything useful. The watchdog reset, needs to
_only_ be reachable if code is running properly. It is a 'bugbear' of mine
that the CCS 'inbuilt' operations that reset the watchdog for you (like
delay), show that they do not understand how a watchdog should be used. |
mdemuth
Posted: Tue Nov 22, 2022 6:47 am |
Strike!
Thanks! |
Joined: 01 Jul 2010 Posts: 9100 Location: Greensville,Ontario
Posted: Tue Nov 22, 2022 9:15 am |
comment : WDT
Generally speaking, do NOT enable the WDT until 100% of the program is 'up and running', ready to sell.
Usually set WDT to x2 or x3 the time for a 'main() loop' to occur ?
If it's enabled before, all sorts of weird and NOT wonderful things can happen, causing no end of grief....and hair pulling ...... |
