rudy
18F26K22 PORT A |
Posted: Thu Oct 27, 2022 8:24 am |
Hi!
I am having trouble to read PORT_A with an optical sensor. It is a simple pulse counter, but I need to detect only when the PIN_A1 goes high.
The strange thing is that, sometimes, when the transition is from high to low, I also have a pulse detected.
As this PIC has a lot of peripherals attached to the ports, I really don’t know what is going on here.
This is my configuration:
SETUP_ADC_PORTS(NO_ANALOGS);
SETUP_COMPARATOR(NC_NC_NC_NC);
SETUP_COUNTERS(RTCC_INTERNAL,RTCC_DIV_16);
SETUP_TIMER_1(T1_INTERNAL|T1_DIV_BY_8);
SETUP_TIMER_2(T2_DISABLED,0xFF,16);
SETUP_TIMER_3(T3_DISABLED|T3_DIV_BY_8);
SETUP_TIMER_4(T4_DISABLED,0xFF,16);
SETUP_TIMER_5(T5_DISABLED|T5_DIV_BY_8);
SETUP_TIMER_6(T6_DISABLED,0xFF,16);
SET_TRIS_A(0b11011111);
SET_TRIS_B(0b11000111);
SET_TRIS_C(0b11010111);
SET_TRIS_E(0b11111111);
LCD_INIT();
RTC_TEST_OSC();
ENABLE_INTERRUPTS(INT_TIMER1);
ENABLE_INTERRUPTS(INT_EXT);
ENABLE_INTERRUPTS(GLOBAL);
And this is my loop:
while(true) //NORMAL WORKING STATE
//DIR -> PIN_A0
//CLK -> PIN_A1
if(INPUT(PIN_A1)&&LOCK_ENCODER)
LOCK_ENCODER=0;
COUNT++;
if(!INPUT(PIN_A1)&&!LOCK_ENCODER)LOCK_ENCODER=1;
Sometimes what seems to be easy becomes very hard.
Any tip?
Regards; |
Posted: Thu Oct 27, 2022 10:30 am |
What is the Vdd voltage of the PIC, and what are the voltage levels on Pin A1 ?
Do either of these function access Port A ?
LCD_INIT();
RTC_TEST_OSC(); |
rudy
Posted: Thu Oct 27, 2022 10:52 am |
Thank you PCM programmer!
All 5 volts! And nobody else use this port.
I start to think that this issue is related with the cable length, around 5 meters between the sensor and the PIC.
The cable capacitance may be doing this! (SUSPICIOUS)
Regards; |
Posted: Thu Oct 27, 2022 11:08 am |
'optical sensor' ?????
You should post the make/model/ link to it.....
distance ( 5 meters +- 15 feet ) shouldn't be a problem
but....
may need shielded cable, good +5 to sensor, proper pullup on data line
hmm..speed ? 'optical sensor' may be 'slow' compared to your loop speed
also
what 'triggers' the sensor ? is the sensor have good square edges during transitions ? |
rudy
Posted: Thu Oct 27, 2022 11:22 am |
It is a regular type, model TCST110
The cable is not shielded, and the speed is not fast.
I will hook my oscilloscope and see better the signal. It is very weird, because when I poll the sensor with a certain low speed, this issue always occurs, but when I speed up a little, the problem disappears.
I am suspicious the cable, because when I was developing the sensor mechanics, the cable between the PIC (development board) and the sensor was about 30 cm, and never this issue happens before.
Also, I will try to replace the cable (it has 4 legs (+5, GND, DIR and CLK)) for a LAN twisted pair, and check if this effect vanishes.
Let’s see!
Regards; |
rudy
Posted: Thu Oct 27, 2022 11:57 am |
Confirmed!
IT IS NOT THE CABLE!
Rsrsrsrsrs (smiling)
Lost in paradise again!
Now move to oscilloscope. Don't know what to do anymore!
Regards! |
Posted: Thu Oct 27, 2022 2:03 pm |
ok, it's what I call a 'flag' sensor... block the IR beam with a flat black bar...
So...need to know what resistors did you use for the LED and the transistor for the optocoupler ? |
rudy
Posted: Thu Oct 27, 2022 3:32 pm |
temtronic wrote: | ok, it's what I call a 'flag' sensor... block the IR beam with a flat black bar...
Well, the LED and Transistor are 1k pulled up. I didn't have time today, but I will go deep tomorrow.
The difference between the development and the final PCB, that is assembled today, is that I added two others NPN BC-548 transistors in the PCB, just to isolate the sensor signal.
The issue for sure is being generated in this area. Sure about that! because when was in development breadboard, these extra transistors weren't there.
Also, at the collector of these transistors, I added two LEDs, just to see the sensor working.
Don't know if I made myself clear on that.
Regards; |
Posted: Thu Oct 27, 2022 9:51 pm |
I can't see any way that two NPN transistors can provide isolation.
Post the circuit used.
Suspicion is that something in this circuit is preventing the signal actually
getting to the signal levels required, or some capacitive effect (could
explain the 'speed' behaviour). |
Posted: Fri Oct 28, 2022 5:57 am |
Had a quick read of the sensor sheet, using 1K for the diode means about 3.5 ma, not the 20 ma they use. It could be the diode isn't putting out a 'lot' of IR energy.... I'd try 330r or 470r
then...
Using the 1K on the transistor side, is 10x bigger than what they use. Again it could be just 'out of spec, a bit'. My gut says 330r should be better
I prefer to put the resistor between the emitter to ground. This gives a positive logic configuration. If the flag IS there, you get a 'one'. TI thermal terminals did this for the 'carriage home' sensors (mid '70s era ). Kinda made sense to me.
This is a classic 'white breadboard' problem. Try a few combinations and see with scope or DVM which parts gives the desired result.
I don't know but IF that pin on the PIC can be configured as an 'ST' input, you'll get better response (cleaner '1-0-1' signals.
Also put a 10-100mfd cap on the +5 AT the sensor. |
rudy
Posted: Fri Oct 28, 2022 7:12 am |
Good day!
Did everything at my hand, found no explanation about this issue. What I did to solve this? Follow one of your valuable tips.
I have some pins not used, C0 and C1, both ST I/O. Just changed to use them. PROBLEM VANISHES.
Thank you all for helping me again..
Best regards; |
Posted: Fri Oct 28, 2022 8:18 am |
NICE !!
Schmitt (sp?) have well defined highs and lows plus 'hysterisis' so the 'ones' and 'zeros' are accurate,repeatable and give 'clean' edges.
You're lucky you have extra pins.....it's easy for a project to grow and either you run out of pins or memory... |
Posted: Mon Oct 31, 2022 3:19 am |
It does suggest, especially since he was seeing an 'edge', that the problem
is actually some pickup in the long cable. Switching to having some voltage
margin by using the Schmitt inputs is 'better', but long term it might be
worth considering if there is anything that could be added to help?.
Simply having a small capacitor across the input, could help get rid of
HF noise. Also where are the resistors placed?. Having the pull-up/down
resistors at the opposite end of the cable to the sensor, implies that the
cable is carrying current, rather than otherwise being a floating cable.
Does help. |
