Posted: Thu Dec 16, 2021 8:52 pm |
It's primarily used to control a DC motor (forward, reverse, brake, hold functions), though it can be used for other applications.
There's millions of 'hits' of the web about H-bridges.
You need to be sure the H-bridge is 'matched' to whatever load you're using. IE: if the motor requires 20 Amps, an H-bridges rated for 1A will NOT work ! poof ! Also , proper wring and EMI protection are critical as well as a solid power supply ! |
