Long press the key on remote PIC
GiG
PostPosted: Sun Sep 05, 2021 4:41 am     Reply with quote
This is a code that works well.
Is there a way to define a function by long pressing the remote key? But I need a way to long press key on ir remote ?
For example after 3 second pressing in case 16.
nec_remote_read(){
  unsigned int16 count = 0x00;
  unsigned int8 i;
for(h=0;h<2;h++){
  SET_TIMER1(0); //9
  while(!input(IR_Sensor) && (count < 0x251C))
    count = GET_TIMER1();
  if( (count > 0x251B) || (count < 0x2134))
     return FALSE;
  SET_TIMER1(0x00); //4.5
  count = 0x00;
  while((input(IR_Sensor)) && (count < 0x1388))
  if( (count > 0x1387) || (count < 0xFA0))
    return FALSE;
  for(i = 0; i < 32; i++){  //32READY
    SET_TIMER1(0x00);
    count=0x00;
    while(!input(IR_Sensor) && (count < 0x28A))
    count=GET_TIMER1();
  if( (count > 0x289) || (count < 0x1F4))
      return FALSE;
    count = 0x00;
    SET_TIMER1(0x00);
  while((input(IR_Sensor)) && (count < 0X708))
  if( (count > 0X707) || (count < 0X190))
      return FALSE;
  if( count > 0X3E8)
      bit_set(ir_code, (0X1F - i));
      bit_clear(ir_code, (0X1F - i));
  return TRUE;
//---------------------------NEC_Remote----------------------------//
//-----------------------------Set_timer---------------------------//
void set_timer()
h_timer=0;
m_timer=0;
int8 timer_counter=0;
while( command !=64){
if(nec_remote_read())
address = ir_code >> 16;
command = ir_code >> 8;
new_command=1;
  if((command==96)&&( new_command==1)) //up key
    if(timer_counter<=7)
    timer_counter++;
    new_command=0;
  if(command==32) //dwn key
  if(timer_counter>=1&( new_command==1))
     timer_counter=timer_counter-1;
     new_command=0;
      switch ( timer_counter){
       Case 0 :
                  h_timer=0;
                  m_timer=0;
       Case 1:
                  h_timer=5;
                  m_timer=0;
       Case 2 :
                  h_timer=10;
                  m_timer=0;
       Case 3 :
                  h_timer=15;
                  m_timer=0;
       Case 4 :
                  h_timer=20;
                  m_timer=0;
       Case 5 :
                  h_timer=30;
                  m_timer=0;
       Case 6 :
                  h_timer=45;
                  m_timer=0;
       Case 7 :
                  h_timer=60;
                  m_timer=0;
//----------------------------IR_receive---------------------------//
void ir_receive(void)
   if(nec_remote_read()){
 switch ( command){
            Case 64 :                //circule
            Case 72:                 //0n 0ff
              Case 120:                //light
              Case 16:                 //timer
              set_timer();
              Case 96:                 //up
              Case 32:                 //down
if(command!=0)
 //display();
void main(){
setup_oscillator(OSC_8MHZ | OSC_PLL_ON);            // Set internal oscillator to 32MHz (8MHz and PLL)
SETUP_TIMER_1(T1_INTERNAL | T1_DIV_BY_8);
while (1)
ir_receive();
PostPosted: Sun Sep 05, 2021 4:49 am     Reply with quote
In the manual, in the FAQ sections, there's a 'timed keypress' chunk of code.
it 'looks' for a pin status AND < certain timout value. Pretty sure you can modify to make it work as you need.
edit: fromt the 'common questions and answers sectio od the CCS C manual....
How do I wait only a specified time for a button press?
The following is an example of how to wait only a specific time for a button press.
#define PUSH_BUTTON PIN_A4
int1 timeout_error;
int1 timed_get_button_press(void){
int16 timeout;
timeout_error=FALSE;
timeout=0;
while(input(PUSH_BUTTON) && (++timeout<50000)) // 1/2 second
delay_us(10);
if(!input(PUSH_BUTTON))
return(TRUE); //button pressed
else{
timeout_error=TRUE;
return(FALSE); //button not pressed timeout occurred
