Timer2 Placement
GiG
Timer2 Placement
PostPosted: Sat Sep 04, 2021 11:43 pm     Reply with quote
Hi, I am using the timer0 in Micro. I wanted to replace with timer 2 instead.
Thanks for the tips on how to write the values and how to calculate them.
I want that prescaler 4 for timer 2, and micro clock 8 MHz.
#INT_TIMER0
void count_overflow()
set_timer0(131);
counter++;
clear_interrupt(INT_TIMER0);
void calculate_time()
{//---------------------------Calculate_time-------------------------//
if (counter>=2000){
   second++;
   counter=0;
if (second>=59){
   minute++;
   second=0;
if (minute>=59){
   hour++;
if (hour>=23){
   hour=minute=second=0;
void main(){
  Setup_timer_0(RTCC_INTERNAL|RTCC_DIV_8);
PostPosted: Sun Sep 05, 2021 1:44 am     Reply with quote
Look in the 16F1939.h file. Look in the section for Timer2.
It shows you what parameters are for setup_timer_2().
Also look in the CCS manual. Download it here:
http://www.ccsinfo.com/downloads/ccs_c_manual.pdf
Look on pages 562 and 563 for setup_timer_2().
PostPosted: Sun Sep 05, 2021 5:08 am     Reply with quote
Also, if you're creating a 'real time clock', see the software 'zero drift RTC' program in the 'code library'. It works for any PIC, any clock.......
