Fabri
Error Not enough RAM for all variables |
Posted: Wed Mar 03, 2021 10:10 am |
I tried to use text table in CCS I already use with XC8 compiler. This because my string isn't length fixed. Below example of structure of table. In production firmware I have 5 tables with total each composed of 40 text string.
When I compile with CCS V5.077 I have compiler error:
Why happens so ? I don't use RAM for tables.
Thanks for help !
cont int *tab_msg_EN[5]{
"11111111\0",
"22222222\0",
"333\0",
"44444\0",
"5555\0",
Fabri
Posted: Wed Mar 03, 2021 11:37 am |
I solved getting back and use array of strings without pointer. |
Posted: Thu Mar 04, 2021 12:56 am |
Here is how to make variable length constant strings work. The program
below displays the following output in MPLAB vs. 8.92 simulator. This was
tested with CCS vs. 5.103. See the CCS manual on page 49.
Quote: |
11111111
22222222
333
44444
5555
Test program:
#include <18F46K22.h>
#use delay(internal=4M)
const int8 tab_msg_EN[][*] = {
"11111111\0",
"22222222\0",
"333\0",
"44444\0",
"5555\0"
int8 i;
for(i=0; i<5; i++)
printf("%s \r", tab_msg_EN[i]);
while(TRUE);
Also, you don't have to put \0 at the end of your strings. The compiler
automatically puts a \0 at the end of a quoted string. So you can do it
like this and it will still work:
"11111111",
"22222222",
"333",
"44444",
"5555"
Fabri
Posted: Thu Mar 04, 2021 1:53 am |
Your help is greatly appreciated. I'm going to work around and test it.
Regards, |
Posted: Thu Mar 04, 2021 2:04 am |
What was originally posted, would work without the problem, with one
simple change.
Just add:
#device PASS_STRINGS=IN_RAM
just up after the processor definitions.
The 'reason' for the problem is simple. On the PIC, the ROM memory
space is a separate address space to the RAM. So trying to declare an array
of pointers results in addresses that are way outside the RAM area.
The PASS_STRINGS option makes the compiler 'virtualise' pointers to the
ROM. This is the default behaviour in XC8.
So:
(Using PCM Programmers example)
const int8 * tab_msg_EN[] = {
"11111111",
"22222222",
"333",
"44444",
"5555"
int8 i;
for(i=0; i<5; i++)
while(TRUE);
Will merrily work. |
Fabri
Posted: Thu Mar 04, 2021 2:11 am |
Very interesting Ttelmah.
Thanks |
