#use rs232
ortegahernandes
#use rs232
PostPosted: Tue Jan 19, 2021 1:44 pm     Reply with quote
Hello good afternoon everyone.
Well at the beginning of the microcontroller programming it is possible to adjust some communication parameters like baudrate stop bit, parity, timeout .....
#user rs232 (baud = 19200, bits = 8, parity = E, timeout = 5)
However at program time I can only modify the baud rate
set_uart_speed (9600, serial)
How do I change the other items above at program times?
PostPosted: Tue Jan 19, 2021 6:57 pm     Reply with quote
Use streams. See the CCS manual:
https://www.ccsinfo.com/downloads/ccs_c_manual.pdf
Then use fputc(), fprintf(), fgetc(), etc. and specify the stream you want
to use in each one of those functions.
PostPosted: Tue Jan 19, 2021 7:12 pm     Reply with quote
Just remember to keep in mind that changing the RS232 parameters could be disasterous unless you properly communications to the other 'device' !!
