colesha
LCD failure to display content with 18f4550 |
Posted: Sat Nov 28, 2020 3:11 pm |
am failing to display contents on the lcd using the 18f4550. The other programs run well like, if i want to blink a led, push buttons, all work fine. The two LCDs work fine with the audrino , but can not work on my pic. Where could i hve gone wrong?
here is a sample code and my LCD configuration
// Interfacing PIC18F4550 with LCD display CCS C code
//LCD module connections
#define LCD_RS_PIN PIN_D0
#define LCD_RW_PIN PIN_D1
#define LCD_ENABLE_PIN PIN_D2
#define LCD_DATA4 PIN_D3
#define LCD_DATA5 PIN_D4
#define LCD_DATA6 PIN_D5
#define LCD_DATA7 PIN_D6
//End LCD module connections
#include <18F4550.h>
#fuses NOMCLR INTRC_IO
#use delay(clock=8000000)
#include <lcd.c>
char i;
void main(){
setup_oscillator(OSC_8MHZ); // Setup internal oscillator @ 8MHz
lcd_init(); // Initialize LCD module
lcd_gotoxy(2, 1); // Go to column 2 row 1
lcd_putc("PIC18F4550");
lcd_gotoxy(1, 2); // Go to column 1 row 2
lcd_putc("LCD example");
for(i = 0; i < 2; i++){ // Shift display right 2 times
delay_ms(200);
lcd_send_byte(0,0x1E);
OUTPUT_HIGH(PIN_C5);
delay_ms(5000);
for(i = 0; i < 14; i++){ // Shift display right 14 times
delay_ms(200);
lcd_putc('f'); // LCD clear
lcd_gotoxy(18, 1); // Go to column 18 row 1
lcd_putc("Hello world!");
lcd_gotoxy(17, 2); // Go to column 17 row 2
lcd_putc("Have a nice day");
for(i = 0; i < 15; i++){ // Shift display left 15 times
delay_ms(200);
lcd_send_byte(0,0x18);
delay_ms(5000);
lcd_gotoxy(3, 1); // Go to column 3 row 1
i = 0;
while(TRUE){
if(input(PIN_C0) == 0){
i++;
if(i > 100)
i = 0;
lcd_gotoxy(7, 2); // Go to column 7 row 2
printf(lcd_putc,"%3u",i); // Write i with 3 numbers max
delay_ms(200);
I have spent some time on this, could anyone please help out? |
Posted: Sat Nov 28, 2020 3:32 pm |
Had a quick look at the datasheet...
it's been years since I used it...
just a guess... as nothing obvious jumps out..
Those pins are also used with the 'Streaming Parallel Port', so you may have to disable that peripheral first.
I haven't used 'lcd.c' in years either, prefer the 'flex_lcd.c' version of the driver.
Posted: Sat Nov 28, 2020 7:04 pm |
One obvious mistake is this:
The lcd.c file says this at the top:
Quote: |
lcd_putc(c) Will display c on the next position of the LCD.
\a Set cursor position to upper left
\f Clear display, set cursor to upper left
\n Go to start of second line
\b Move back one position
If you want to clear the screen, do it like this, with a backlash f:
Posted: Sun Nov 29, 2020 6:13 am |
You may need to add a delay_ms(500); just after the lcd_init(); to allow the LCD module to properly reconfigure into 4bit mode and be 'ready'.
I don't know if lcd_init() of the lcd.c driver does wait before returning to main(). I 'think' flex_lcd.c does but since dayone I've always had a delay_ms(500); after the lcd_init() call... old habits die hard I suppose...
Also reduce code to a simple 'hello World'... get it working THEN add more messages...
makes it easier to debug !!
Posted: Sun Nov 29, 2020 8:10 am |
Actually the delay needs to be before lcd_init.
It is common to need a delay here. There are two separate 'issues'. First,
the standard Hitachi chip needs 90mSec after power is applied before it
can accept commands. Most of the drivers do include this delay, but a lot
of the 'clone' controllers need more delay than this. The second reason,
is that the PIC often starts when the voltage is well below the voltage
needed to start the LCD's, so again more delay is needed. |
colesha
Posted: Sun Nov 29, 2020 3:31 pm |
temtronic wrote: | Had a quick look at the datasheet...
Thanks, How do u disable SSP?
i have tried using the flec lcd too and a simple hello. but all in vane |
colesha
Posted: Sun Nov 29, 2020 3:40 pm |
Ttelmah wrote: | Actually the delay needs to be before lcd_init.
I will do that in the morning, add a delay and use the flex lcd driver. Also i witl try out other ports and a standby Pic. |
colesha
Posted: Sun Nov 29, 2020 3:42 pm |
PCM programmer wrote: | One obvious mistake is this:
Thanks PCM,
Let me try with a simple code.
Is there any special way i should configure the PIC before using it, liking setting fuses etc? |
Posted: Sun Nov 29, 2020 3:53 pm |
from the 4550 device header file...
// PSP Functions: SETUP_PSP, PSP_INPUT_FULL(), PSP_OUTPUT_FULL(),
// PSP_OVERFLOW(), INPUT_D(), OUTPUT_D()
// PSP Variables: PSP_DATA
// Constants used in SETUP_PSP() are:
#define PSP_ENABLED 0x10
#define PSP_DISABLED 0
#byte PSP_DATA= 0xF83
so something like ....
setup_psp(PSP_DISABLED);
..might work
however according to the datasheet, the default state is disabled. That doesn't mean that CCS' 'default' state is disabled, so better to be sure !
also the CCP uses some of that port, so try disabling it as well. |
Posted: Sun Nov 29, 2020 5:27 pm |
CCS doesn't touch the streaming parallel port. So it's disabled on powerup
and it stays that way. |
colesha
Posted: Mon Nov 30, 2020 5:05 am |
For sure all not working, it's like the PIC is not communicating to the LCD. I am doing this on the breadboard. I am supplying both the VDD with 5V and both the VSS to ground. Pin MCLR through a resistor send 10k. I have chance the Flex lcd driver to use port B, tried a simple hello world program, but not displaying still.
Is my hardware connection fine? The connections are really firm on the breadboard.
I have used another new PIC as well. |
Posted: Mon Nov 30, 2020 5:26 am |
hmm, post your 'hello World' program. I have a 46k22 running at 64MHz using the internal oscillator on a 20+year old breadboard with a 20x4 LCD , RTCEEP, DS18B20 as well as a USBTTL module plus a blinking 'I'm running' LED..so I KNOW it works....
colesha
Posted: Mon Nov 30, 2020 10:55 am |
temtronic wrote: | hmm, post your 'hello World' program. I have a 46k22 running at 64MHz using the internal oscillator on a 20+year old breadboard with a 20x4 LCD , RTCEEP, DS18B20 as well as a USBTTL module plus a blinking 'I'm running' LED..so I KNOW it works....
Hello, thanks for the response, here it is. I have also got a 20x4 LCD but yet to test it, when i reach home. This is for the 20x4 lcd:
//LCD Module Connections
#define LCD_RS_PIN PIN_B1
#define LCD_RW_PIN PIN_B2
#define LCD_ENABLE_PIN PIN_B0
#define LCD_DATA4 PIN_B4
#define LCD_DATA5 PIN_B5
#define LCD_DATA6 PIN_B6
#define LCD_DATA7 PIN_B7
//End LCD Module Connections
#fuses NOMCLR NOBROWNOUT NOLVP INTRC_IO
#use delay (clock=8000000)
#include <lcd420.c>
setup_oscillator(OSC_8MHZ); // Set the internal oscillator to 8MHz
Delay_ms(500);
lcd_putc('\f'); //Clear Display
lcd_gotoxy(1,1);
lcd_putc("Hello World");
lcd_gotoxy(1,2);
lcd_putc("Welcome To");
lcd_gotoxy(1,3);
lcd_putc("LCD Library");
for the pic, do i have to connect the LCD RW pin to ground? same for D0-D3? Is it mandatory? |
Posted: Mon Nov 30, 2020 11:28 am |
1) connect the LCD_RW pin to the PIC B2 pin, as shown in the LCD module connections at the top of your program. This connection allows the PIC to both write to the LCD as well as read from it. The 'driver' may allow for the option of 'write only', however the actual update of LCD will be slower as the 'ready' bit isn't polled so fixed delays are usually used.
2) regarding D0...D3, that depends upon the make/model of the LCD module. The ones I use, I can leave 'floating' or not connected. The LCD module datasheet should explain the required connection for 4bit mode vs 8bit mode.
3) There is a 'contrast' pin, usually pin 3 of the LCD module and it is critical that it's properly connected. Typically it needs about 0.5v, though, again, check the datasheet. Some pre-made modules have a pot to allow you to adjust the voltage for best 'contrast'. |
colesha
Posted: Tue Dec 01, 2020 1:45 am |
Thanks Temtronic,
It has really worked, the issue was the LCD RW and Contrast pins. I had to connect the RW pin to the PIC instead of connecting it to the ground. I also connected the contrast through a 10K variable resistor.
Am now Happy.
Thanks for your support always. |
