gtx15
Variables |
Posted: Sat Nov 28, 2020 5:46 am |
Is there a way to see where a certain variable is used through out my program?
For example a variable called "c". I just cant search for "c" because it also in comments.
Thanks. |
Posted: Sat Nov 28, 2020 6:02 am |
Easy answer....
Give it a better name ?? I know, kinda obvious, usually variable names reflect(tell) what they are used for. Easy with modern lanugages...when I started variables were limited to 1 or 2 characters.
I have to admit I use short names. I can't type so naming something like 'remote_temperature_sensor_number_1_from_greenhouse' isn't a good idea ! |
gtx15
Posted: Sat Nov 28, 2020 7:19 am |
Found a way. If I comment out the declare line for that variable I get errors whenever that variable is used when compiling. |
dyeatman
Posted: Sat Nov 28, 2020 7:55 am |
You might try getting a C Indexer/Cross Ref program that will give you a
list of all the variables and their location/use. There are a number of free ones out there.
Below is example output from an xref program I wrote for my own use in
Delphi years ago called CCSList customized for CCS code:
Cross Reference Listing for the CCS "C" file:
>>>>>> ocraff.c
Include File Processing Option Not Selected
Number of lines in this source file: 409
INCLUDES:
#include <16F628.H>
FUSES LINE:
#fuses EC,PUT,WDT,NOPROTECT,MCLR,NOLVP,NOCPD
DEVICE LINES:
#device *=16 ICD=TRUE
#device *=16
PRIORITY LINE:
#PRIORITY RDA, TIMER1
DEFINES:
#define START_Signal_In PIN_A0 //pin 17 /pin RA0
#define AFF_Power PIN_A1 //pin 18 /pin RA3
#define buffer_len 0x40 // 64 chars
#DEFINE TIMER1START 21000 // ctr start value for 10ms timer
#DEFINE FLASH 50 // 50 x 10 = 500ms flash time
#define bkbhit (next_in!=next_out)
#define LED_ON 1
#define LED_OFF 0
#BIT DEFINES:
#no bit defines found
#BYTE DEFINES:
#no byte defines found
PROTOTYPES:
void serial_isr();
void process();
byte gethexbyte(char digit);
INTERRUPT ROUTINES:
#INT_TIMER1
#INT_RDA
VARIABLES LISTING: (* indicates the declaration line in the Main file)
cmd_buff: *101 ***** Not used *****
aff_data_in: *103 ,274,277,291,327,329
aff_idle: *103 ,198,275,285,313,337
bad_packet: *103 ,286,317,322,331,340
curr_cmd: *102 ,350,354
c: *103 ,164,166
CRC_IN: *103 ,298,300,301,308
t: *103 ,149,154 |
_________________ Google and Forum Search are some of your best tools!!!! |
