Handling of INT_UART1E interrupt [CLOSED]
benoitstjean
PostPosted: Thu Nov 26, 2020 10:07 am     Reply with quote
Device: PIC24EP512GP806
Compiler: 5.026
Hi guys.
Very (very) rarely, the INT_UART1E interrupt is triggered. Don't know when and don't know what causes it and unless I'm not seeing this right, I can't seem to find much info in the full spec sheets or extra specs "Section 17. UART" document. In the full specs, it is referred-to as <U1E – UART1 Error Interrupt> but can't find any much more info.
But when that error happens, it seems that the MCU doesn't process anything afterwards and is stuck there.
In the interrupt routine, I print the status of the following registers and they seem fine but they always seem to have the same values so maybe I should print others?
U1STA  : 0x0510
U1MODE : 0x8000
U1TXREG: 0x0000
U1RXREG: 0x000A
As a temporary measure, I guess I could simply reset the MCU but that's not ideal. Any suggestions or ideas on what else I should look at and how to handle this so that the code simply carries-on?
Thanks.
Ben
PostPosted: Thu Nov 26, 2020 11:02 am     Reply with quote
Framing error probably.
You have to read the character. The error clears itself when a character
is read. Untill it is cleared it'll stay set.
benoitstjean
PostPosted: Thu Nov 26, 2020 11:10 am     Reply with quote
So in the INT_UART1E interrupt, should I just do a blind getc( UART )?
PostPosted: Thu Nov 26, 2020 12:22 pm     Reply with quote
Yes, the UART errors all 'attach' to the character currently at the top
of the buffer. So when this is read the errors disappear with it (unless there
are multiple errors).
benoitstjean
PostPosted: Sun Nov 29, 2020 8:11 am     Reply with quote
Ok thanks. In the interrupt routine, I've added a simple if( kbhit()) getc();
Ben
