Posted: Thu Oct 22, 2020 7:27 am |
OK, found it... 2nd post, after b).....
Guess I was focussed on the green 'restart_watchdog'......thinking...hmmm..wonder if that's causing a problem.... |
VincentJ
Posted: Thu Oct 22, 2020 7:38 am |
The INT_RDA does not affect TO_UART2_ON :
Code: | #INT_RDA //RS232 RECEIVE DATA AVAILABLE - One CHAR is READY to be READ.
void RDA_isr(void)
int t;
buffer[next_in]=fgetc(PORT1);
t=next_in;
if(++next_in==BUFFER_SIZE)
{ next_in=0; }
if(next_in==next_out)
{ next_in=t; }
Compteur_Data_In++;
In fact INT_RDA2 was on the same pattern and not disabled. I modified it as I tried to fix the issue.
In the version I showed you, INT_RDA2 clears the RDA2_TimeOUT counpter and then puts the 20ms timeout ON (the full trame duration is less 0.5ms).
When the timeout is reached in INT_TIMER0 (when RDA2_TimeOUT >= 3), INT_RDA2 is disabled and à flag is set (UART2_TrameRecue = 1;).
In the main loop : if the flag UART2_TrameRecue is set, the buffer is copied to another and INT_RDA2 is enabled. |
VincentJ
Posted: Thu Oct 22, 2020 8:09 am |
I tried without the WD but it doesn't change anything |
VincentJ
Posted: Thu Oct 22, 2020 9:02 am |
A little more :
I noticed a difference in the disassembly listing of the RDA2_isr between the versions that work and those that do not :
For those that does not work, each time, the compiler includes the reference name of a variable and I do not understand what it is doing there...
It is sometimes à global variable, sometimes à local one. In the exemple it is the name of a function argument which is called by EXT1_isr :
OK program :
https://www.dropbox.com/s/geqcl7jdxo639tu/prog_memory_ok.png?dl=0
NOK program :
https://www.dropbox.com/s/fvhb0ppy3sz4imn/prog_memory_nok.png?dl=0
INT_EXT1 code (which is known to be too long)
Code: | #INT_EXT1 // interruption des I2C IO EXTENDER
void EXT1_isr(void)
// EXT1_isr_Flag = 1;
// Output_LOW(TEST_LED);
Disable_interrupts(INT_EXT1); // Couper l'interruption Externe 1
Stop_WS2812_Stream=ON; // Indiquer au programme qui s'occupe d'envoyer la trame aux LED's quelle a été interrompu
FLAG_INT_EXT1=1;
ClearOled=0; // indiquer que l'écran peut être effaçé
Refresh_HoistInformation=1; // Indiquer qu'il faut rafraichir l'écran OLED
Programme_Buzzer (1,5,20); // un petit BIP!!
//enable_interrupts(INT_EXT1); // Ré enclencher l'interruption EXTERNE 1
Prototype :
Code: | void Programme_Buzzer (unsigned int8 NombreImpulsion,unsigned int16 DureeImpulsionON_ms,Unsigned int16 DureeImpulsionOFF_ms);
Posted: Thu Oct 22, 2020 9:18 am |
this...
Quote: | Programme_Buzzer (1,5,20); // un petit BIP!! |
appears to be some kind of function using delays...25ms worth of them...
One should never, ever put (or call ) any function that has delays.
ISRs must be short and fast. Set a flag and let main() handle whatever action is required based upon the flag status. |
VincentJ
Posted: Thu Oct 22, 2020 9:27 am |
I understand but as far as EXT_INT1 is not triggered the program should work shouldn't it ? |
