US2066 Driver.
gtx15
US2066 Driver.
PostPosted: Thu Jul 02, 2020 1:11 pm     Reply with quote
Anyone know of a US2066 Driver ? I'm messing around with a 4x20 NHD oled with no luck.
PostPosted: Fri Jul 03, 2020 1:55 pm     Reply with quote
This one can be easily translated to CCS:
https://github.com/NewhavenDisplay/NHD_US2066
DigitalWrite() in Arduino translates to output_bit() in CCS.
Delay() in Arduino translates to delay_ms() in CCS.
Example:
Arduino code:
void command(unsigned char c)
  unsigned char i, temp;
  switch(mode)
    case 0:   digitalWrite(CS, LOW);
              PORTA = c;
              digitalWrite(RS, LOW);
              digitalWrite(E, HIGH);
              delay(1);
              digitalWrite(E, LOW);
              digitalWrite(CS, HIGH);
Translated to CCS:
#define LOW 0
#define HIGH 1
#define CS  PIN_B0   // Or whatever pins you are using for it
#define RS  PIN_B1
#define E   PIN_B2
#byte PORTA = getenv("SFR:PORTA")  // Use LATA if using PIC18F
unsigned char mode = 0; // 0 = 8-bit parallel 6800 mode; 1 = i2c mode; 2 = SPI mode;
const char slave2w = 0x78;  // CCS uses 8-bit slave address
switch(mode)
    case 0:  output_bit(CS, LOW);
             PORTA = c;
             output_bit(RS, LOW);
             output_bit(E, HIGH);
             delay_ms(1);
             output_bit(E, LOW);
             output_bit (CS, HIGH);
daveh
PostPosted: Wed Dec 07, 2022 6:03 am     Reply with quote
http://www.ccsinfo.com/forum/viewtopic.php?t=59920&start=0&postdays=0&postorder=asc&highlight=us2066
I posted driver code here
