int32 overflow
Goto page Previous  1, 2, 3
kmp84
PostPosted: Fri Apr 17, 2020 3:46 am     Reply with quote
This is in fact 'why' the
CCS fp maths format differs from the IEEE format, allowing a saving of
about four instructions.
I didn't know that...Rolling Eyes , but thinking for few my projects where I need converting back to IEEE 754 and may be my program is slower than using directly IEEE 754?
but gives you the extra output bits allowing you
to 'know' if an overflow has occurred
Where CCS tell how to access those bits?
PostPosted: Fri Apr 17, 2020 6:26 am     Reply with quote
They are the upper 32bits of the 64bit result. Normally when you overflow multiplication, you get a wrong answer because the upper bits of the result are lost. with _mul, you get the full up to 64 bit answer
consider 0x20000 multiplied by 0x20000, two 32 bit numbers:
       x 00020000
00000004 00000000
Normally that value of 4 is lost because it is overflow and multiplication of two 32bit values in C results in a 32bit result. with the _mul() function it always returns a result twice as large as the largest operand (up to 32bit operand). So instead of losing the overflow bits (the 4), you now get the whole answer with _mul(), assuming your operands are no bigger than 32bits
kmp84
PostPosted: Fri Apr 17, 2020 6:50 am     Reply with quote
Yes Mr. jeremiah it is logic answer. I'm still thinking for bits... not for bytes:)
Thanks,
PostPosted: Fri Apr 17, 2020 7:39 am     Reply with quote
It's also worth repeating my comments about using unions:
    union {
       unsigned int32 words[2];
       unsigned int64 whole;
   } value;
   int32 num1, num2;
   value.whole=_mul(num1,num2);
   //at this point, value.words[1] contains any overflow bits
With this if value.words[1]!=0 you have had an overflow.
value.words[0] is the int32 result.
Makes testing very easy... Very Happy
PostPosted: Fri Apr 17, 2020 9:01 am     Reply with quote
kmp84 wrote:
Yes Mr.jeremiah it is logic answer. I'm still thinking for bits... not for bytes:)
Thanks,
My previous response indicated that the bits were stored in the upper 32bits of the 64bit result. Ttelmah's post shows you how to access them using a union.
kmp84
PostPosted: Fri Apr 17, 2020 12:41 pm     Reply with quote
Yes, the union are great things Smile
Thanks guys. Everything is clear!
I hope this long thread will be useful and CCS correct "STATUS" core register.
Best Wishes!
PostPosted: Fri Apr 17, 2020 2:46 pm     Reply with quote
Best Wishes!
They may not see it. This is only a user forum. They generally only do official support through phone/email. I would definitely recommend sending your suggestions to CCS
PostPosted: Sat Apr 18, 2020 2:06 am     Reply with quote
It's worth perhaps pointing out that this is not really a required 'fix'. C
itself defines the behaviour when a operation overflows as 'undefined'.
There is no requirement for this to be flagged in any way.
Now it would be 'nice' if it was, and once we are through Covid-19,
I will make a suggestion to CCS, that they might consider adding this,
but it very much is something that isn't required....
Page 3 of 3
