ortegahernandes
PIC24FV32KA304 Pin RA5 MCLR/NOMCLR |
Posted: Thu Mar 26, 2020 5:39 pm |
PIC24FV32KA304
How to use the RA5 pin on the ccs, if there are fuse options and there is no option "NOMCLR" ?
#device PIC24FV32KA304
#nolist
//////// Program memory: 11264x24 Data RAM: 2048 Stack: 31
//////// I/O: 37 Analog Pins: 16
//////// Data EEPROM: 512
//////// Fuses: WRTB,BSSH5376,BSSH2560,BSSH1152,BSSS5376,BSSS2560,BSSS1152
//////// Fuses: NOBSS,WRT,PROTECT,FRC,FRC_PLL,PR,PR_PLL,SOSC,LPRC,LPFRC_DIV
//////// Fuses: FRC_DIV,SOSC_DIGITAL,SOSC_ANALOG,LPRCLOW,LPRCHIGH,IESO,EC,XT
//////// Fuses: HS,NOPR,OSCIO,POSCFREQ_L,POSCFREQ_M,POSCFREQ_H,SOSC_LOW
//////// Fuses: SOSC_HIGH,CKSFSM,CKSNOFSM,NOCKSFSM,WPOSTS1,WPOSTS2,WPOSTS3
//////// Fuses: WPOSTS4,WPOSTS5,WPOSTS6,WPOSTS7,WPOSTS8,WPOSTS9,WPOSTS10
//////// Fuses: WPOSTS11,WPOSTS12,WPOSTS13,WPOSTS14,WPOSTS15,WPOSTS16,WDT32
//////// Fuses: WDT128,WINDIS,NOWDT,WDT_NOSL,WDT_SW,WDT,NOBROWNOUT
//////// Fuses: BROWNOUT_SW,BROWNOUT_NOSL,BROWNOUT,LVR,PUT,ALTI2C1,BORV_LOW
//////// Fuses: BORV_HIGH,BORV_MID,MCLR,ICSP3,ICSP2,ICSP1,DEBUG,DSWDT_=n
//////// Fuses: DSWDTCK_SOSC,DSWDTCK_LPRC,DSBOR,DSWDT |
Posted: Thu Mar 26, 2020 6:26 pm |
That's just comments in a file. It probably has a typo. I see MCLR there so it would have to have NOMCLR. NOMCLR compiles fine on the latest release of PCWHD for that chip. |
Posted: Fri Mar 27, 2020 2:27 am |
Yes, and does generate the NOMCLR setting in the .lst file output:
Configuration Fuses:
Word 1L: 000F NOWRTB NOBSS
H: 0000
Word 2L: 0000
H: 0000
Word 3L: 0003 NOWRT NOPROTECT
H: 0000
Word 4L: 00E2 PR SOSC_ANALOG LPRCHIGH IESO
H: 0000
Word 5L: 003A HS OSCIO POSCFREQ_H SOSC_HIGH CKSFSM
H: 0000
Word 6L: 005F WPOSTS16 WDT128 WINDIS NOWDT
H: 0000
Word 7L: 001C NOBROWNOUT NOLVR PUT NOALTI2C1 BORV_LOW NOMCLR
H: 0000
Word 8L: 0083 ICSP1 NODEBUG
H: 0000
Word 9L: 00DF DSWDT_33SEC DSWDTCK_LPRC DSBOR NODSWDT
H: 0000
Word 7. |
ortegahernandes
Posted: Fri Mar 27, 2020 6:06 am |
So, I even tried to put the "NOMCLR". It compiles normally, but it seems that it generates an error in the .hex file.
When I put it to record the error,
when it doesn't have this function it records normally.
Is it a problem in the recorder software ?
Like, because it no longer has the MCLR pin, it generates the error?
https://ibb.co/51MSD75
https://ibb.co/s1rVb45 |
