srikala
PIC18F27k42 UART2, PIN_A5 and PIN_A4 cannot assign error |
Posted: Mon Mar 23, 2020 11:11 am |
In below code pin selection assigned is error when compiled, for pin_a5 and pin_a4, need help what might be wrong.
#include <18f27k42.h>
#fuses HS,WDT,NOPROTECT,BROWNOUT
#use delay(clock=20000000,RESTART_WDT)
#pin_select U1RX=PIN_C5
#pin_select U1TX=PIN_C0
#USE RS232(UART1,baud=9600,xmit=pin_C0,rcv=pin_C5,bits=8,stop=1,parity=n,STREAM=MODEM)
#pin_select U2RX=PIN_A5
#pin_select U2TX=PIN_A4
#USE RS232(UART2,baud=9600,xmit=pin_A4,rcv=pin_A5,bits=8,stop=1,parity=n,STREAM=PC1)
#pin_select SCL1=PIN_C3
#pin_select SDA1=PIN_C4
#use i2c(I2C1,MASTER, sda=PIN_C4, scl=PIN_C3, stream=STREAM_1)
#pin_select SCL2=PIN_C1
#pin_select SDA2=PIN_C2
#use i2c(I2C2,master, sda=PIN_C2, scl=PIN_C1, stream=STREAM_2)
#include<float.h>
#include <input.c>
#include<math.h>
#include<stdio.h>
#include<stddef.h>
#include<stdlib.h>
#include<string.h>
set_tris_b(0XFF); // 00000011
set_tris_c(0XF0); // 1111 0000
set_tris_a(0XFF);
delay_ms(50);
enable_interrupts(INT_RDA);
enable_interrupts(INT_RDA2);
SETUP_WDT(WDT_ON);
lcd_send_byte(0,1);
RESTART_WDT();
//Routines
srikala
Posted: Mon Mar 23, 2020 11:17 am |
The following is error message when compiled:
Quote: |
Invalid Pre-Processor directive Invalid Pin: PIN_A5 can not be assigned to U2RX.
Invalid Pre-Processor directive Invalid Pin: PIN_A4 can not be assigned to U2TX. |
Posted: Mon Mar 23, 2020 11:20 am |
I downloaded a copy of the datasheet from uChip and I don't see RA4, RA5 being PPS pins, so not remappable. Table #1, page #9.
dang it's a 800+ page PRELIMIMARY datasheet !
also...
There's a lot of errors within the rest of the program...
One should never use the WDT until 100% of main() actually runs 100%.
No need for set_tris() as the compiler automatically handles that.
Never enable an Interrupt unless the 'handler' aka ISR or Interrupt Service Routine is coded.
Function call lcd_init but no LCD driver.
Loading several libs and not needing them. |
Posted: Tue Mar 24, 2020 2:37 am |
As always you need to check data for the chip you use.
In this case Table 17-1, and 17-2. These describe what can be routed
where. UART1 receive can only connect to PortB or PortC, and the same
limitation exists for the TX line. The UART's generically cannot be
connected to PortA. Hence the error....
The PortA pins are re-map-able for some other devices, but not this. |
srikala
Posted: Thu Mar 26, 2020 1:13 am |
Thank you Ttelmah,
I changed my hardware to portc , pin_c5 and pin_c0 and tried the below code, reference from example files.
Could see junk data on PC termina (Tera Term) continuously, sent data from pc terminal and nothing displayed on my lcd second line, only first line displayed as written in code. the ground of pc usb and my hardware board are lopped properly.
Verified the controller port pins and MAX3232 pins with multi-meter, observed there is voltage change in transmit and receive lines.
Voltage levels at Controller Pin’s
@PIN_C0(TX1) – 1.018 to 0.952
@PIN_C5(RX1) – 0.016 to 0.184
Voltage levels at MAX3232 pin’s
@Pin 14 (T1OUT) -> -0.858 to -0.812
@Pin 13 (R1IN) -> 1.812 TO 1.800
Powered my board from PC USB also, could see only junk on pc terminal and nothing on lcd display.
#use delay(clock=20000000)
#USE RS232(UART1,baud=9600,xmit=pin_C0,rcv=pin_C5,bits=8,stop=1,parity=n,stream=pc)
#define BUFFER_SIZE 32
BYTE buffer[BUFFER_SIZE];
BYTE next_in = 0;
BYTE next_out = 0;
char string[8];
#int_rda
void serial_isr() {
int t;
buffer[next_in]=getc();
t=next_in;
next_in=(next_in+1) % BUFFER_SIZE;
if(next_in==next_out)
next_in=t; // Buffer full !!
#define bkbhit (next_in!=next_out)
BYTE bgetc() {
BYTE c;
while(!bkbhit) ;
c=buffer[next_out];
next_out=(next_out+1) % BUFFER_SIZE;
return(c);
#include<2X16LCD.c> //LCD display
delay_ms(50);
enable_interrupts(int_rda);
enable_interrupts(global);
lcd_gotoxy(1,1);
printf(lcd_putc,"Serial Comm");
fprintf(PC,"\r\n\Running...\r\n");
do {
delay_ms(10000);
fprintf(PC,"\r\nData From PC");
while(bkbhit)
putc( bgetc() );
lcd_gotoxy(1,2);
printf(lcd_putc,"Resp:%s",bgetc());
} while (TRUE);
Posted: Thu Mar 26, 2020 1:57 am |
Big problems. You are reading the character, which means it has 'gone'....
Then you are printing incorrectly:
while(bkbhit)
putc( bgetc() );
//at this point the buffer has been emptied.
lcd_gotoxy(1,2);
//You now try to print a single character, as a string.
} while (TRUE);
A single character from the buffer, is a character, not a string. %s tries
to print a string, which means it'll print till it happens to meet a null
in memory. LCD will be garbage....
You need to read the characters into a 'string' buffer, then terminate
this with a NULL, if you want to use %s. |
