24FJ128GA704 PWM w/o using a timer?
Goto page Previous  1, 2
allenhuffman
PostPosted: Thu Mar 12, 2020 11:26 am     Reply with quote
gaugeguy wrote:
When you have several different 'lettered' outputs, look at the CCP_PULSE_STEERING_x to determine which output it gets directed to.
Refer to the processor .h file
Ah. Was my issue here that there were TWO CCP2s and this the #use couldn’t tell which one?
Allen C. Huffman, Sub-Etha Software (est. 1990) www.subethasoftware.com
Embedded C, Arduino, MSP430, ESP8266/32, BASIC Stamp and PIC programmer.
www.whywouldyouwanttodothat.com ?
PostPosted: Thu Mar 12, 2020 12:29 pm     Reply with quote
The #USE PWM, is a powerful tool, but comes at a very large cost. It
removes direct control of what resources are actually used. The timing
controls produce bulky code, and you are having to 'guess' what
resources are actually use.
If prototyping and I want a frequency quickly, I'll use #USE, but as soon
as I want to use explicit resources I'll switch to controlling things myself.
This way I can assign the resources and know what hardware is used.
It's a 'shortcut', but equivalent to one that takes you straight across
a bog....
allenhuffman
PostPosted: Fri Mar 13, 2020 8:11 am     Reply with quote
a bog....
Thanks -- good to know. I was experimenting with it this morning and that left me with more questions than answers.
I do like that it calculates everything for me (prescaler).
I have successfully used PWM on our speaker to play music, and hardware is going to swap two pins for me so I can test that on the backlight.
I am now trying to move the other two timers to just Timer 1. We need a 32-bit counter for hardware being added to the board, soon.
PostPosted: Fri Mar 13, 2020 8:51 am     Reply with quote
Remember 'input capture' can again support using it's own internal
counters.
allenhuffman
PostPosted: Wed Mar 18, 2020 10:47 am     Reply with quote
counters.
Is there an example of this somewhere?
PostPosted: Thu Mar 19, 2020 1:10 am     Reply with quote
On the setup_capture, just use 'CAPTURE_SYSTEM_CLOCK'. This then
makes the capture unit clock from the system clock using it's own internal
counter.
Page 2 of 2
