Pointer in struct .....
Flavio58
PostPosted: Tue Jun 24, 2003 8:35 am     Reply with quote
I tried to use some pointers into a structure but the compiler show me an error ...
My struct si :
struct errorMessage {
char *language1;
char *language2;
} errs[] = {
{ "msg1", "msg2" },
{ "msg3", "msg4" }};
Why this construct is not correct ?
Original Post ID: 144515518
Sherpa Doug
Re: Pointer in struct .....
PostPosted: Tue Jun 24, 2003 9:02 am     Reply with quote
:=I tried to use some pointers into a structure but the compiler show me an error ...
:=My struct si :
:=struct errorMessage {
:= char *language1;
:= char *language2;
:=} errs[] = {
:= { "msg1", "msg2" },
:= { "msg3", "msg4" }};
:=Why this construct is not correct ?
It looks like you are trying to use a pointer into ROM. This is forbidden by the Harvard architecture of the PIC processors, not just by the compiler. Some compilers have work-arounds but they are all convoluted and painful.
Look in the CCS manual under "Common Questions and Answers" at "How can a constant data table be placed in ROM? on page 189 of my manual.
Also search for "pointer to ROM" on this BBS.
Original Post ID: 144515526
R.J.Hamlett
PostPosted: Tue Jun 24, 2003 9:09 am     Reply with quote
:=My struct si :
:= char *language1;
:= char *language2;
:=} errs[] = {
Because you cannot have pointers to constant strings. This is a well documented 'lack' in the CCS C, caused by the way they handle the processors architecture (remember the RAM, and ROM, are addressed seperately).
As written, the "MSGx" declarations, are automatically constants, and then the compiler can't deal with these for pointers.
You can have the pointers fine, but only by initialising the arrays 'after the event', and using RAM to store the strings.
You can also 'kludge' it, by using something like:
const char message[] = "msg1\0msg2\0msg3\0msg4"
#define MSGADD1 0
#define MSGADD2 5
#define MSGADD3 15
#define MSGADD4 20
Then in your structure, store the 'MSGADD' value, and when you want to access the string, use 'message[address]', starting at the defined address, rather than the pointer form.
Original Post ID: 144515527
