[SOLVED]CCS C- Structures with Pointers
camleot23
PostPosted: Mon Sep 02, 2019 4:37 am     Reply with quote
Hello all,
Again me Smile This time when I load this code to my dsPIC, I can't see my car's model and colour. I exactly get this output from RS232:
First car is :
The color of it :
Max. Speed is : 320
The motor type: 4.19
I want to use pointers. I can see the integers but not strings.
Here is my code:
#include <./33EP64MC206.h>
#use delay(internal=42MHz)
#FUSES NOJTAG                   //JTAG disabled
#FUSES CKSFSM                   //Clock Switching is enabled, fail Safe clock monitor is enabled
#FUSES FRC
#FUSES NOOSCIO
#use rs232(baud=9600,parity=N,stop=1,xmit=PIN_G7 ,rcv=PIN_G6)
struct vehicle
    char model[10];
    char color[10];
    int max_speed;
    float motor;
void show(struct vehicle *car)
    printf("First car is : %s \r\n",(*car).model[8]);
    printf("The color of it : %s \r\n",(*car).color[5]);
    printf("Max. Speed is : %d\r\n",(*car).max_speed);
    printf("The motor type: %f \r\n",(*car).motor);
   setup_oscillator(OSC_INTERNAL,42000000)
   struct vehicle first;
   struct vehicle *pointer;
   pointer=&first;
   (*pointer).model[8]="mercedes";
   (*pointer).color[5]="black";
   (*pointer).max_speed=320;
   (*pointer).motor=4.20;
   output_toggle(pin_b5);
      show(pointer);
      delay_ms(3000);
PostPosted: Mon Sep 02, 2019 5:06 am     Reply with quote
First. to use a structure pointer, look at the -> operator. Much easier to
use in your function.
Then though the big problem is the initialisation. You can't copy a string
with =. This is generic in C. You have to use strcpy, to copy the actual
'string' into the target array. This is why the strings are blank.
camleot23
PostPosted: Mon Sep 02, 2019 5:18 am     Reply with quote
Thank you very much for your time Ttelmah. It's working:)
#FUSES FRC
#FUSES NOOSCIO
struct vehicle
    char model[10];
    char color[10];
    int max_speed;
    float motor;
  printf("First car is : %s \r\n",car->model);
    printf("The color of it : %s \r\n",car->color);
    printf("Max. Speed is : %d\r\n",car->max_speed);
    printf("The motor type: %f \r\n",car->motor);
  pointer=&first;
   strcpy(pointer->model,"mercedes");
   strcpy(pointer->color,"black");
   pointer->max_speed=320;
   pointer->motor=4.20;
      show(pointer);
      delay_ms(3000);
