If i use a 47K resistor as pull up on PORTa will the digital input be unstable?
I intend to use ADC or Digital Input on the same pin, selected by software.
Posted: Wed Aug 21, 2019 12:35 am
Depends totally on your environment.
47K is adequate to 'pull up' a digital signal that is only using relatively low
signal capacitance (so a short line), and not requiring fast slew rates (so
not trying to send fast edges). Remember as well that the analog signal
(when enabled), needs to meet the ADC impedance requirements, and will
be driving into this pull up. How do you visualise switching these signals?.
