call function with const tables.
georpo
PostPosted: Wed Jul 10, 2019 11:03 pm     Reply with quote
Hi all!
I am using an oled with fonts created with "TheDotFactory".
Then I set/clear the pixels with my custom code:
void OledText(int TextX,int TextY,int Size){
   int Character=0,Offset=0,Width=0,Height=0,S=0,E=0,p=0;
   int BitComp=0;
   while(TextBuffer[p]){
    Character=TextBuffer[p++];
    Character-=32;
    if(Size==1){
     Width=arialUnicodeMS_8ptDescriptors[Character][0];
     Height=arialUnicodeMS_8ptDescriptors[Character][1];
     Offset=arialUnicodeMS_8ptDescriptors[Character][2];
    if(Size==2){
     Width=arialUnicodeMS_10ptDescriptors[Character][0];
     Height=arialUnicodeMS_10ptDescriptors[Character][1];
     Offset=arialUnicodeMS_10ptDescriptors[Character][2];
    if(Size==3){
     Width=arialUnicodeMS_12ptDescriptors[Character][0];
     Height=arialUnicodeMS_12ptDescriptors[Character][1];
     Offset=arialUnicodeMS_12ptDescriptors[Character][2];
    if(Size==4){
     Width=arialUnicodeMS_14ptDescriptors[Character][0];
     Height=arialUnicodeMS_14ptDescriptors[Character][1];
     Offset=arialUnicodeMS_14ptDescriptors[Character][2];
    if(Size==5){
     Width=arialUnicodeMS_16ptDescriptors[Character][0];
     Height=arialUnicodeMS_16ptDescriptors[Character][1];
     Offset=arialUnicodeMS_16ptDescriptors[Character][2];
    BitComp=1;
    for(S=0;S<Height;++S){           //Do 'Height' vertical pixels
     for(E=0;E<Width;++E){           //Do 'width' horizontal pixels
      if(Size==1){
       if(arialUnicodeMS_8ptBitmaps[Offset+E]&BitComp) SetPixel(TextX+E,TextY+S);
       else ClearPixel(TextX+E,TextY+S);
      if(Size==2){
       if(arialUnicodeMS_10ptBitmaps[Offset+E]&BitComp) SetPixel(TextX+E,TextY+S);
      if(Size==3){
       if(arialUnicodeMS_12ptBitmaps[Offset+E]&BitComp) SetPixel(TextX+E,TextY+S);
      if(Size==4){
       if(arialUnicodeMS_14ptBitmaps[Offset+E]&BitComp) SetPixel(TextX+E,TextY+S);
      if(Size==5){
       if(arialUnicodeMS_16ptBitmaps[Offset+E]&BitComp) SetPixel(TextX+E,TextY+S);
     }                          //Finished 1 line of pixels
     ClearPixel(TextX+E,TextY+S);   //Clear 1 pixel to delete previous content.Related to 1 pixel space below
     BitComp*=2;               // Move to Higher bit for next compare
     if(BitComp>128){
      BitComp=1;               //Reset comparison to lowest bit
      Offset+=Width;            //and move to next set of bytes
    }                        //finished 1 character
    TextX+=Width+1;            //increment X by last character width +1 pixel space
I will need to add more fonts, so is there any more efficient way instead of all those "IFs"?
Thanks for any feedback!
George.
allenhuffman
PostPosted: Fri Jul 12, 2019 10:38 am     Reply with quote
You might consider making it table driven. What data type are the "arialUnicodeMS_8ptDescriptors" things?
You'd have a structure that contains the Size you want to look up, and the addresses of each of your fonts. Something like this:
typedef struct
    int     Size;
    int8    *FontPtr; // Whatever your font type is
} FontInfoStruct;
FontInfoStruct FontInfo[] =
    // Size Font
    { 1,    arialUnicodeMS_8ptDescriptors },
    { 2,    arialUnicodeMS_10ptDescriptors },
    { 3,    arialUnicodeMS_12ptDescriptors },
    { 4,    arialUnicodeMS_14ptDescriptors },
    { 5,    arialUnicodeMS_16ptDescriptors },
    { 0,    0 } // End of Table
Then you could just loop through that table looking for the matching size, and when you find it, you also have the address for the font structure you want to use. Something like this:
   // Size is your target size
   // Character is your character
    int Width, Height, Offset;
    Width = 0;
    Height = 0;
    Offset = 0;
    int Entry = 0;
    do
        if (FontInfo[Entry].Size == Size)
            Width = FontInfo[Entry].FontPtr[Character][0];
            Height = FontInfo[Entry].FontPtr[Character][1];
            Offset = FontInfo[Entry].FontPtr[Character][2];
        Entry++;
    } while (FontInfo[Entry].Size != 0);
    printf( "Size: %u  Character: %u  Width: %u  Height %u  Offset: %u\r\n",
            Size, Character, Width, Height, Offset);
This is just pseudo code to give you an idea of what I mean.
