CCS and Warp13 config word setting - How to do it automatica
Ron
PostPosted: Wed Jan 08, 2003 4:36 am     Reply with quote
Is there a way to set the code protection bits in Warp 13 software automatically to the desired settings? By a keyword in the source code?
It would be great if this were possible, because now I have to uncheck the code protection bits in Warp 13 every time I program a new PIC18F...
Best regards,
Ron
Original Post ID: 10533
Kieran Fitzgerald
Re: CSS and Warp13 config word setting - How to do it automa
PostPosted: Sun Jan 12, 2003 6:57 am     Reply with quote
:=Hello,
:=Is there a way to set the code protection bits in Warp 13 software automatically to the desired settings? By a keyword in the source code?
:=It would be great if this were possible, because now I have to uncheck the code protection bits in Warp 13 every time I program a new PIC18F...
:=Best regards,
:=Ron
The #FUSE keyword does all this?
I have not used it for protection but appears to default to off.
Kieran
Original Post ID: 10625
Ron
PostPosted: Tue Jan 14, 2003 2:34 am     Reply with quote
With the use of correct #fuse statement to disable code protection, Warp13 still enables code protection for (000h-0200h and Data EEPROM)??
Does #fuse WRTB not work?
Regards,
Ron
:=:=Hello,
:=:=Is there a way to set the code protection bits in Warp 13 software automatically to the desired settings? By a keyword in the source code?
:=:=It would be great if this were possible, because now I have to uncheck the code protection bits in Warp 13 every time I program a new PIC18F...
:=:=Best regards,
:=:=Ron
:=The #FUSE keyword does all this?
:=I have not used it for protection but appears to default to off.
:=Kieran
Original Post ID: 10679
Ron
PostPosted: Thu Jan 23, 2003 8:00 am     Reply with quote
Downloaded a new version of CSS (v3.136)... problem solved.
Now, when I turn all code protection off with #fuse, WARP13 automatically turns all protection off when I start it up.
Don't ask me why but the new CSS version seems to solve the problem...?
:=With the use of correct #fuse statement to disable code protection, Warp13 still enables code protection for (000h-0200h and Data EEPROM)??
:=Does #fuse WRTB not work?
:=Regards,
:=Ron
:=:=:=Hello,
:=:=:=Is there a way to set the code protection bits in Warp 13 software automatically to the desired settings? By a keyword in the source code?
:=:=:=It would be great if this were possible, because now I have to uncheck the code protection bits in Warp 13 every time I program a new PIC18F...
:=:=:=Best regards,
:=:=:=Ron
:=:=The #FUSE keyword does all this?
:=:=I have not used it for protection but appears to default to off.
:=:=Kieran
Original Post ID: 10929
