Function Pointer fails when defined outside of structures
Pets
PostPosted: Mon May 06, 2019 11:35 am     Reply with quote
The function pointer defined in the structure works fine.
The 'TestSpeak' function pointer only works when declared in a local function not as a global.
Any thoughts???
Configure
// CPU
#include <18F27K42.h>
// PPS Module
#pin_select U1RX=PIN_C7
#pin_select U1TX=PIN_C6
// Misc
#fuses RSTOSC_HFINTRC_64MHZ,NOWDT,PROTECT,NOMCLR
#use delay(clock=64000000)
#use rs232(UART1, STREAM=UART_1, BAUD=115000, XMIT=PIN_C6, RCV=PIN_C7, ERRORS, DISABLE_INTS)
Define
void ProcessDog(void* aCounter);
void ProcessCat(void* aCounter);
void ProcessBird(void* aCounter);
typedef void(*funcPtr)(void*);
typedef struct
funcPtr Speak; // This function Pointer compiles and works fine
}ST_ANIMAL;
Declare
ST_ANIMAL stAnimals[3];
//funcPtr TestSpeak; // If declared here TestSpeak compiles with error shown on line 80
fprintf(UART_1, "Woof %LU \r\n", (int16)aCounter[0]);
fprintf(UART_1, "Meow %LU \r\n", (int16)aCounter[0]);
fprintf(UART_1, "Tweet %LU \r\n", (int16)aCounter[0]);
// Data
int idx;
int16 counter;
//funcPtr TestSpeak; // If declared here TestSpeak compiles and works fine
// Init
counter = 0;
TestSpeak = &ProcessDog;
stAnimals[0].Speak = &ProcessDog;
stAnimals[1].Speak = &ProcessCat;
stAnimals[2].Speak = &ProcessBird;
// Loop!
fprintf(UART_1, "Test Function Pointers \r\n\n");
TestSpeak(&counter); // compile error shows on this line 'Function used but not defined'
for(idx = 0 ; idx < 3 ; idx++)
stAnimals[idx].Speak(&counter); // This call works fine
counter++;
fprintf(UART_1, "\n");
delay_ms(2000);
PostPosted: Mon May 06, 2019 2:02 pm     Reply with quote
It's interesting that it accepts it in the array. However the reason it doesn't
work is the syntax being used to call the function. The correct C syntax to
call a function defined by a pointer is:
(*TestSpeak)(&counter);
Try it. Smile
Pets
PostPosted: Mon May 06, 2019 2:28 pm     Reply with quote
Thanks Ttelmah
Yes it did work!!!
Interesting I do not have to do that if I declare TestSpeak in main().
PostPosted: Mon May 06, 2019 11:50 pm     Reply with quote
It is slightly 'interesting'. The problem is that calling without the
dereferencing, is asking the code to call a function, not telling it to
call a variable containing a function address. Now the compiler seems
to be automatically dereferencing when the value is in the array or
declared locally. This is 'non documented' behaviour, so I'd prefer to
allways explicitly dereference. This way you won't get unexpected
results!...
Pets
PostPosted: Thu May 09, 2019 7:44 am     Reply with quote
will do... better safe than sorry!
Thanks for all your help and advice...
