Jhonatan
Compiler error initialising strings? |
Posted: Mon Mar 18, 2019 11:26 am |
I'm compiling this exact code in CCS PIC C version 5.025.
If I put 11 in SIZE, which would be the correct size since all strings are 10 positions plus \0 added by compiler, the variables simply don't get the correct value. This happens in Proteus and also in the product the code goes to.
For example:
STR_GIRO should be " GIRO \0" but instead is "GGGGGGGGGGG".
STR_EXTE should be " EXTENSAO \0" but instead is " EXTENSA\0\0\0".
If I put 10 in SIZE, variables are truncated but correct, just without ending \0.
If I put 12 in SIZE, variables are correct but with twice \0 at the end.
If I put 11 in SIZE, but exclude variables STR_EXTJB to STR_F_HIDR, the rest is as it should be.
Changing between styles int8 STR_GIRO [SIZE] = " GIRO " to int8 STR_GIRO [SIZE] = {" GIRO "} does not change the result.
Why would this be happening?
#include <18F67K22.h>
#device ADC = 12
#FUSES WDT
#FUSES WDT256
#FUSES VREGSLEEP
#FUSES SOSC_DIG
#FUSES NOXINST
#FUSES NOFCMEN
#FUSES NOIESO
#FUSES PUT
#FUSES BROWNOUT
#FUSES BORV27
#FUSES BORM_MED
#FUSES RTCOSC_INT
#FUSES MSSPMSK7
#FUSES MCLR
#FUSES STVREN
#FUSES BBSIZ2K
#FUSES PROTECT
#FUSES NOCPB
#FUSES NOCPD
#FUSES NOWRT
#FUSES NOWRTC
#FUSES NOWRTB
#FUSES NOWRTD
#FUSES NOEBTR
#FUSES NOEBTRB
#use delay(crystal = 20000000)
#zero_ram
#define SIZE 11
int8 STR_GIRO [SIZE] = " GIRO ";
int8 STR_ELEV [SIZE] = " ELEVACAO ";
int8 STR_INCL [SIZE] = "INCLINACAO";
int8 STR_EXTE [SIZE] = " EXTENSAO ";
int8 STR_GUIN [SIZE] = " GUINCHO ";
int8 STR_EXTJB [SIZE] = " EXT JIBE ";
int8 STR_INCJB [SIZE] = " INC JIBE ";
int8 STR_AUX [SIZE] = " AUXILIAR ";
int8 STR_MANIP [SIZE] = "MNP. POSTE";
int8 STR_CH5 [SIZE] = " CANAL 5 ";
int8 STR_CH6 [SIZE] = " CANAL 6 ";
int8 STR_CH7 [SIZE] = " CANAL 7 ";
int8 STR_CH8 [SIZE] = " CANAL 8 ";
int8 STR_CESTO0[SIZE] = "GIRO INF. ";
int8 STR_CESTO1[SIZE] = "ELEV. INF.";
int8 STR_CESTO2[SIZE] = "GIRO SUP. ";
int8 STR_CESTO3[SIZE] = "ELEV. SUP.";
int8 STR_CESTO4[SIZE] = "BASCULAM. ";
int8 STR_F_HIDR[SIZE] = "FER. HIDR.";
int8 joys[][SIZE] = {" GIRO ", " ELEVACAO ", "INCLINACAO", " EXTENSAO ", " GUINCHO ", " EXT JIBE ", " INC JIBE ", " AUXILIAR "}; // Initial names
while (TRUE) {
restart_wdt();
// Names will be sprinted to joys during execution
dluu13
Posted: Mon Mar 18, 2019 12:08 pm |
How are you printing them out or otherwise inspecting their contents?
I didn't put it on my PIC, but it works alright on the compiler on my computer. |
Posted: Mon Mar 18, 2019 12:14 pm |
this...
restart_wdt();
is really not required and should NOT be coded until the product is ready to be shipped ! |
Jhonatan
Posted: Mon Mar 18, 2019 12:29 pm |
In deed there are no errors at all (please disconsider the variables are not used in the code posted).
I'm debugging the values of the variables in Proteus CPU variables right after
the source enters main.
On the product there are lines like:
sprintf(joys[0], STR_GIRO);
Then later:
fprintf(lcd_write, "%s ", joys[0]);
Also, it works fine if all other variables but joys are const. |
Posted: Mon Mar 18, 2019 12:34 pm |
The program below works with CCS vs. 5.082. It displays the following
output in the Output Window in MPLAB vs. 8.92 simulator:
Quote: | GIRO
ELEVACAO
INCLINACAO
EXTENSAO
GUINCHO
EXT JIBE
INC JIBE
AUXILIAR
Test program:
Code: | #include <18F67K22.h>
#device ADC = 12
#fuses NOWDT, BORV27, PUT, SOSC_DIG, NOPROTECT
#define SIZE 11
int8 joys[][SIZE] =
{" GIRO "},
{" ELEVACAO "},
{"INCLINACAO"},
{" EXTENSAO "},
{" GUINCHO "},
{" EXT JIBE "},
{" INC JIBE "},
{" AUXILIAR "}
int8 i;
for(i = 0; i < 8; i++)
printf("%s\r", joys[i]);
while(TRUE);
Jhonatan
Posted: Mon Mar 18, 2019 12:50 pm |
Hi PCM programmer.
Would you remake the test with this code?
This does not print even "TEST":
#device ADC = 12
#define SIZE 11
int8 joys[][SIZE] =
{" GIRO "},
{" ELEVACAO "},
{"INCLINACAO"},
{" EXTENSAO "},
{" GUINCHO "},
{" EXT JIBE "},
{" INC JIBE "},
{" AUXILIAR "}
int8 i;
printf("TEST");
sprintf(joys[0], STR_CH5);
printf("%s\r", joys[0]);
while(TRUE);
This prints "TEST":
#device ADC = 12
#define SIZE 11
/*int8 STR_GIRO [SIZE] = " GIRO ";
int8 STR_F_HIDR[SIZE] = "FER. HIDR.";*/
int8 joys[][SIZE] =
{" GIRO "},
{" ELEVACAO "},
{"INCLINACAO"},
{" EXTENSAO "},
{" GUINCHO "},
{" EXT JIBE "},
{" INC JIBE "},
{" AUXILIAR "}
int8 i;
printf("TEST");
//sprintf(joys[0], STR_CH5);
//printf("%s\r", joys[0]);
while(TRUE);
Posted: Mon Mar 18, 2019 12:55 pm |
There are a couple of comments:
5.025, was early enough that it may still have the gobal interrupts
being disabled by printf. Problem appeared in the early V5 compilers,
and was fixed some time later. Might still be applying in this version.
He has the watchdog enabled. This might well be interfering with
an output like printf.
Also as has already been commented about the watchdog, don't
enable 'PROTECT' until development is finished. Having this enabled
results in extra lives being used on the program memory when
developing.
He also has a boot block size enabled. Why?. |
Posted: Mon Mar 18, 2019 1:06 pm |
There's definitely a problem with vs. 5.025. In his post with the two
programs, I compiled the first one with vs. 5.082 and ran it in MPLAB 8.92
simulator and I got:
That's correct.
Then I uninstalled vs. 5.082 and installed vs. 5.025. I re-compiled and
got this:
Also, Ttelmah, I got rid of all that in my test program. |
Jhonatan
Posted: Mon Mar 18, 2019 1:33 pm |
Sorry Ttelmah and temtronic, this is actually 9th version of a program already running on an old product and I'm just adding some extra functions, which are the extra strings I put here. My first post had unnecessary coding to show the problem.
Thank you PCM programmer for the better code and for testing this out for me, that confirms my thoughts.
This code (which is the same as previous but commented) shows the point. When I added extra string names for the joys, it stopped working. Literally commenting and uncommenting these lines screws the behaviour:
#device ADC = 12
#define SIZE 11
// These names will be sprinted to joys during execution
// if I comment from here
// to here, it works fine
int8 joys[][SIZE] = { // This is just to initialize
{" GIRO "},
{" ELEVACAO "},
{"INCLINACAO"},
{" EXTENSAO "},
{" GUINCHO "},
{" EXT JIBE "},
{" INC JIBE "},
{" AUXILIAR "}
printf("TEST");
while(TRUE);
I think the compiler is doing something wrong as there is more RAM to be initialized.
Also, on Proteus (sorry for insisting in Proteus), there are warnings concerning PC 0x0242 to PC 0x0246 where attempts to change RTCVALL and RTCVALH were denied and also "external memory not modeled, write to MEMCON just store data in the register".
All that disappears if I comment that block.
I will try to get the last version of the compiler. Would you recommend any particular or vs. 5.082?
Thank you all. |
Posted: Mon Mar 18, 2019 2:28 pm |
Yes. A quick test shows it works on 5.028, but not on the versions before.
The functions being complained about by Proteus are not at the heart of the
problem, they are just things that Proteus doesn't know how to model. |
