Zek_De
about int1 |
Posted: Sun Mar 17, 2019 4:43 am |
Hi, I have seen a variable int1 in Modbus library in CCS C, and I wonder if uint8_t two_characters=0; increment two times like that:
two_characters++; is 1
two_characters++; is 0
two_characters++; is 1 am I right? These are the code.
void incomming_modbus_serial() {
char c;
static int1 two_characters=0;
static unsigned int8 datah,datal,data;
c = fgetc(MODBUS_SERIAL) & 0x7F;
if (!modbus_serial_new)
if(modbus_serial_state == MODBUS_START)
if(c==':')
modbus_serial_state++;
else if(modbus_serial_state == MODBUS_GETADDY)
if(!two_characters)
if(c>=0x41)
datah=((c-0x37)<<4);
datah=((c-0x30)<<4);
modbus_serial_lrc=0;
if(c>=0x41)
datal=c-0x37;
datal=c-0x30;
data=(datah | datal);
modbus_rx.address=data;
modbus_calc_crc(data);
two_characters++;
else if(modbus_serial_state == MODBUS_GETFUNC)
if(!two_characters)
if(c>=0x41)
if(c>=0x41)
datal=c-0x37;
datal=c-0x30;
modbus_rx.func=data;
modbus_rx.len=0;
modbus_rx.error=0;
two_characters++;
else if(modbus_serial_state == MODBUS_GETDATA)
if(c=='\r')
modbus_rx.len--;
modbus_serial_lrc-=data;
else if(!two_characters)
if(c>=0x41)
two_characters++;
if(c>=0x41)
datal=c-0x37;
datal=c-0x30;
if (modbus_rx.len>=MODBUS_SERIAL_RX_BUFFER_SIZE)
modbus_rx.len=MODBUS_SERIAL_RX_BUFFER_SIZE-1;
modbus_rx.data[modbus_rx.len]=data;
modbus_rx.len++;
two_characters++;
else if(modbus_serial_state==MODBUS_STOP)
if(c=='\n')
modbus_serial_lrc=((0xFF-modbus_serial_lrc)+1);
if(modbus_serial_lrc==data)
modbus_serial_new=TRUE;
modbus_serial_state=MODBUS_START;
two_characters=0;
#if (MODBUS_TYPE == MODBUS_TYPE_MASTER)
modbus_serial_wait=MODBUS_SERIAL_TIMEOUT;
Joined: 01 Jul 2010 Posts: 9101 Location: Greensville,Ontario
Posted: Sun Mar 17, 2019 5:35 am |
Yes, by looking at the code (quickly), they use it to determine which incoming data byte is the MSB and the LSB of a 'pair' of data. I'm assuming the MODBUS data is in pairs.
Rather clever really, as a simple quick test determines if high byte or low byte. Actually any '1 of 2' choices.
You could also use it as an 'odd or even' test
Zek_De
Posted: Sun Mar 17, 2019 6:01 am |
Okay temtronic,
changing I wonder here was this
and you checked it is right. Thank you |
Posted: Sun Mar 17, 2019 6:50 am |
Of course the easy check to this ,is to have the program display the 'two_characters' value, say to a PC or LCD module....
If you have a one spare I/O pin, asttache a TTL<>USB module and use this to send 'debug data' to a PC running a 'terminal program'. This is also a great way to look at ANY variable and any point of the program. |
Posted: Sun Mar 17, 2019 6:58 am |
The only thing 'puzzling', is the phrasing of your question...
You say "uint8_t two_characters=0;". Er. unt8_8... No the variable is int1,
and importantly _static_. So the value is initialised to '0' on the first pass
(this is what it is explicitly initialised 'to'), and then increments 0,1,0,1 etc.. |
Zek_De
Posted: Mon Mar 18, 2019 5:11 am |
Yes I sould check it using LCD but I didnt have it and I needed learn it very fast, and thank you all help. |
