art
Convert Binary to Decimal number |
Posted: Wed Mar 06, 2019 12:39 am |
I'm trying to convert 16 digit Binary number to a Decimal number. My code can only convert a 5 digit binary number. If the input is more than 5 digits, it will not convert to decimal number correctly. How to make it convert a 16 digit binary number into a decimal number ? I've converted this code from a C programming example and it can convert 16 binary digits to decimal perfectly.
#include <18F4550.h>
#fuses HSPLL,NOWDT,PROTECT,NOLVP,NODEBUG,USBDIV,PLL5,CPUDIV1,VREGEN
#use delay(clock=48000000)
#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7,ERRORS)
#include <string.h>
#include <input.c>
#include <stdio.h>
#include <stdlib.h>
#include <usb_cdc.h>
#include <math.h>
char c;
int8 i ;
char d,key;
long int n1, n,p=1;
long int dec=0,k=1,j,m;
usb_init_cs();
while (TRUE)
usb_task();
if (usb_cdc_kbhit())
c=usb_cdc_getc();
if (c=='\n') {putc('\r'); putc('\n');}
if (c=='\r') {putc('\r'); putc('\n');}
while(true)
d = usb_cdc_getc();
if(d=='B') // push B for Binary conversion
while (key!=32) // push SPACE BAR to stop
printf(usb_cdc_putc,"Input a binary number :");
&n=get_long_usb();
n1=n;
for (j=n;j>0;j=j/10)
m = j % 10;
if(k==1)
p=p*1;
p=p*2;
dec=dec+(m*p);
k++;
printf(usb_cdc_putc,"\nThe equivalent Decimal Number : %ld \n\n",dec);
} key=0;
Posted: Wed Mar 06, 2019 1:35 am |
The problem is using 'get_long_usb'. Long is only a 16bit number. So 0 to
65535. Using this to input a binary number limits you to just 5 digits...
Simple answer is to read the value yourself:
char c;
unsigned int32 result;
result=0;
while (TRUE)
c=usb_cdc_getc();
if (!isamong(c, "01")) //needs 'ctype.h'
break; //not '0' or '1' terminate
result*=2;
result+= c-'0';
//'result' now contains the decoded number
printf(usb_cdc_putc,"\nThe equivalent Decimal Number : %ld \n\n",result);
For each digit you input simply multiply the result 'so far' by 2, and
add in the value of this digit.
Type anything other than '0' or '1' and it terminates. |
art
Posted: Wed Mar 06, 2019 2:07 am |
Dear Ttelmah,
Thank you very much....it works ! |
