CCS support for version checking at compile time? [Solved] |
Posted: Fri Feb 15, 2019 3:26 pm |
I've searched and either I'm not using the proper keywords or what I'm looking for doesn't exist.
Does CCS have some kind of support for a compiler environment check? For example, let's say I create a project and eventually release something. I use compiler version 5.x, and leave comments in the code saying as much. A colleague then edits the project to make a minor change but uses compiler version 5.y and - for argument's sake - something breaks.
It would be useful to force the compiler to check what compiler version is actually being used, and generate an error if it's not what it is supposed to be.
I realize that I could simply put in a Code: | #warning Version 5.x must be used!!! | but that would assume that people read compiler warnings.
Anyone know if this is supported? |
Posted: Fri Feb 15, 2019 3:38 pm |
Nevermind: I knew I had seen something about compiler version checking/restriction. If you use the IDE, it's in Options->Project, General. Checkbox for "Use specific compiler version" |
Posted: Fri Feb 15, 2019 6:59 pm |
We also do a precompiler check against the version and issue either a #warning or #error if the compiler version doesn't match.
Something like:
#if getenv("VERSION") != 5.080
#error Using wrong compiler version
Posted: Sun Feb 17, 2019 2:15 pm |
That's exactly what I was looking for. Cheers! |
bkamen
Posted: Thu Feb 28, 2019 1:21 am |
newguy wrote: | That's exactly what I was looking for. Cheers! |
Don't forget to change the OP subject to include "SOLVED" somehow.
