BLL
Joined: 11 Nov 2006 Posts: 181 Location: Birmingham, UK
Nested loop problem |
Posted: Mon Feb 04, 2019 10:55 am |
I am using compiler 5.015. The circuit uses 3 push buttons for user selections.
After start up, the program enters a for(;;) loop and waits for a button to be pressed.
The centre button calls a function to set the RTC, the right button switches the display backlight on. So far, so good!
The left button calls the doCycle() function, which also has a for(;;) loop in it and here lies the problem. On returning from this function, the buttons no longer behave! Pressing the centre does not call the RTC setting function, but runs the doCycle function again! It appears that the 2nd for(;;) loop is screwing things up. I can find no way to cure this and don't understand why it's behaving as it is.
The code below shows the main.c and switch.c, but I have omitted the ds1302.c and LCD.c functions:
main.c
#include <18F2550.h>
#device *=16
#device HIGH_INTS=TRUE
#FUSES HSPLL //Crystal osc <= 4MHz
#FUSES PLL1
#FUSES CPUDIV1
#FUSES NOLVP //No low voltage prgming, B5(PIC18) used for I/O
#FUSES NOWRTD //Data EEPROM is not write protected
#FUSES NOIESO //Internal External Switch Over mode disabled
#FUSES NOPBADEN //Port B pins are digital on reset
#FUSES NOWRTC //configuration registers not write protected
#FUSES NOLPT1OSC //Timer1 not configured for low-power operation
//#FUSES NOMCLR //Master Clear pin disabled (proto only)
#FUSES MCLR //for PCB version
#FUSES NOXINST //Must be used with CCS compiler
#use delay(clock=48000000) //CPU clocks at this due to the PLL
//Cooking Timer, February 2019
Designed for backlit 20x4 LCD
#include "k:\PICC\v5l\Projects\CookTimer\CookTimer.h"
#include "k:\PICC\v5l\Projects\CookTimer\DS1302.C"
#include "k:\PICC\v5l\Projects\CookTimer\Flex_LCD420.C"
#include "k:\PICC\v5l\Projects\CookTimer\Switch.C"
#include <math.h>
#include <stdlib.h>
#define BL PIN_A3
#define LED PIN_B3
#define RTCC_PRESET 64750
void set_line_4();
void doCycle();
void setup();
void delay_minute(int16 counter, int1 state);
void get_value(int8 min, int8 max, int8 lcd_cur_x, int8 index);
void get_td(int8 min, int8 max, int8 lcd_cur_x, int8 index, int8 val);
int8 rtc_update_count = 0;
int8 year = 19, mth = 1, day = 1, hr = 0, min = 0, dow, sec;
int1 backlight;
int16 count;
int16 wait_hr, wait_min, cook_hr, cook_min;
int16 wait_minutes, cook_minutes;
char version[6];
//holds waiting & cooking times
int8 data_array[4];
//holds date, time & dow
int8 td_array[6];
char const dayOfWeek[8][4] =
"", "Sun", "Mon", "Tue", "Wed", "Thu", "Fri", "Sat"
}; //days of week, 1 = Sun
char const msg[5][21] =
"START CLK BL",
"DOWN NEXT UP",
"Set the date & time:",
"NO YES",
"Clear OK "
}; //4th line messages
#int_rtcc
void rtcc_isr()
if(rtc_update_count > 9)
rtc_get_date(day, mth, year, dow);
rtc_get_time(hr, min, sec); //seconds not displayed
rtc_update_count++;
update_switch_status(); //poll the switches
set_rtcc(RTCC_PRESET);
setup_adc_ports(NO_ANALOGS);
setup_adc(ADC_OFF);
setup_timer_0(RTCC_INTERNAL|RTCC_DIV_256);
setup_timer_1(T1_DISABLED);
setup_timer_2(T2_DISABLED, 0, 1);
setup_timer_3(T3_DISABLED | T3_DIV_BY_1);
setup_vref(FALSE);
rtc_init();
strcpy(version, "1.20"); //set version here
output_bit(BL, true);
clear_interrupt(INT_RTCC);
enable_interrupts(INT_RTCC);
enable_interrupts(global);
//rtc_get_date(day, mth, year, dow);
//rtc_get_time(hr, min, sec); //seconds not displayed
//Read and save the initial state of the switches.
gc_old_switch_status = read_switches();
printf(lcd_putc, "\fCooking Timer\n(c) 2019 B.L. Lonnon\nVersion %S",
version);
delay_ms(3000);
output_bit(BL, false);
lcd_putc('\f');
lcd_gotoxy(1, 4);
printf(lcd_putc, "%s", msg[0]);
for(;;)
CBFlag = false;
//backlight control
if(gc_rt_button_state == SW_PRESSED && backlight == false)
count = 0;
backlight = true;
if(backlight == true)
count++;
if(count > 5000)
backlight = false;
output_bit(BL, backlight);
lcd_gotoxy(1, 1);
printf(lcd_putc, "%s %02u/%02u/%02u %02u:%02u",
dayOfWeek[dow], day, mth, year, hr, min);
if(gc_lt_button_state == SW_PRESSED)
doCycle();
if(CBFlag == true)
CBFlag = false;
setup();
}//end for
}//end main
void doCycle()
set_line_4();
value = 0;
lcd_gotoxy(1,2);
printf(lcd_putc, "Waiting time: ");
lcd_gotoxy(1, 1);
//set waiting hr
get_value(0, 23, 15, 0);
wait_hr = data_array[0];
//set waiting minute
get_value(0, 59, 18, 1);
wait_min = data_array[1];
printf(lcd_putc, "Cooking time: ");
lcd_gotoxy(1, 1);
//set waiting hr
get_value(0, 23, 15, 2);
cook_hr = data_array[2];
//set cooking minute
get_value(0, 59, 18, 3);
cook_min = data_array[3];
//clear setting line and line4
lcd_gotoxy(1,2);
lcd_putc(" ");
lcd_gotoxy(1,3);
lcd_putc(" ");
lcd_gotoxy(1,4);
lcd_putc(msg[4]);
lcd_gotoxy(1,2);
lcd_putc("Press OK to start");
for(;;)
if(gc_lt_button_state == SW_PRESSED) //NO
wait_hr = 0;
wait_min = 0;
cook_hr = 0;
cook_min = 0;
lcd_putc("\f");
lcd_gotoxy(1,1);
lcd_gotoxy(1, 4);
goto end;
if(CBFlag == true)
lcd_putc("\f");
CBFlag = false;
lcd_gotoxy(1, 1);
lcd_gotoxy(1,3);
wait_minutes = (60L * wait_hr) + wait_min;
cook_minutes = (60L * cook_hr) + cook_min;
output_low(PIN_C7);
delay_minute(wait_minutes, false);
output_high(PIN_C7);
output_high(LED);
delay_minute(cook_minutes, true);
output_low(PIN_C7);
lcd_putc("\f");
lcd_gotoxy(1, 1);
lcd_gotoxy(1, 1);
lcd_gotoxy(1,3);
printf(lcd_putc,"Cooking Finished! %02u", value);
delay_ms(3000);
lcd_putc("\f");
lcd_gotoxy(1, 1);
lcd_gotoxy(1,4);
lcd_putc(msg[0]);
output_low(LED);
}//end if
}//endfor
end:;
void set_line_4()
lcd_putc('\f');
//DOWN NEXT UP
lcd_gotoxy(1, 4);
lcd_putc(msg[1]);
//void get_td(int8 min, int8 max, int8 lcd_cur_x, int8 index, int8 val)
void setup()
lcd_gotoxy(1, 1);
lcd_putc(msg[2]);
lcd_gotoxy(1, 3);
lcd_putc(" ");
lcd_gotoxy(1, 4);
lcd_putc(msg[1]);
//read RTC stored values
lcd_gotoxy(1, 2);
printf(lcd_putc, "%02u/%02u/%02u %02u:%02u (%s)",
day, mth, year, hr, min, dayOfWeek[dow]);
//set day
get_td(0, 31, 1, 0, day);
//set mth
get_td(0, 12, 4, 1, mth);
//set year
get_td(0, 50, 7, 2, year);
//set hr
get_td(0, 23, 10, 3, hr);
//set min
get_td(0, 59, 13, 4, min);
//set dow
get_td(1, 7, 16, 5, dow);
day = td_array[0];
mth = td_array[1];
year = td_array[2];
hr = td_array[3];
min = td_array[4];
dow = td_array[5];
rtc_set_datetime(day, mth, year, dow, hr, min);
lcd_putc('\f');
lcd_gotoxy(1, 1);
lcd_gotoxy(1, 4);
lcd_putc(msg[0]);
void delay_minute(int16 counter, int8 state)
int8 k;
ldiv_t lidiv;
//delays for count mimutes
int16 j;
lcd_gotoxy(1,3);
if(state == false)
lcd_putc("Waiting for ");
lcd_putc("Cooking for ");
for (j = counter; j > 0L; j--)
lidiv=ldiv(j, 60L);
lcd_gotoxy(13,3);
printf(lcd_putc, "%02lu:%02lu..", lidiv.quot, lidiv.rem);
lcd_gotoxy(1, 1);
for(k = 0; k < 60; k++)
//set waiting & cooking values
value = 0;
do
//place marker on line 3 to show what's being altered
lcd_gotoxy(lcd_cur_x, 3);
lcd_putc("°°");
if(value > max)
value = min;
if(value < min)
value = max;
lcd_gotoxy(lcd_cur_x, 2);
if((index == 0) || (index == 2))
printf(lcd_putc, "%02u:", value);
printf(lcd_putc, "%02u", value);
if(CBFlag == true)
}while(true);
CBFlag = false;
//erase marker
lcd_putc(" ");
data_array[index] = value;
value = 0;
//set date, time & dow
value = val;
do
lcd_putc("°°");
if(value > max)
value = min;
if(value < min)
value = max;
//date, so needs / separator
if(index < 2)
printf(lcd_putc, "%02u/", value);
//time, so needs : separator
if(index == 3)
if((index == 2) || (index == 4))
//dow, so needs a string
if(index == 5)
printf(lcd_putc, "(%s)", dayOfWeek[value]);
if(CBFlag == true)
}while(true);
CBFlag = false;
//erase marker
lcd_putc(" ");
td_array[index] = value;
value = 0;
switch.c
#include "K:\Picc\v5l\Projects\CookTimer\Switch.h"
//switch.c -- Debounces the switches.
//Note: Only the Right and Left buttons have auto-repeat code.
#define ENTER_SWITCH_PIN PIN_B6
#define RT_SWITCH_PIN PIN_B7
#define LT_SWITCH_PIN PIN_B5
signed int value; //value from up/down buttons
signed int value_min = 0; //minimum lower limit for value (normally = 0,
//but is -1 for backlight to allow toggling on either button)
boolean CBFlag; //indicates whether centre button is pressed or not
//Return the status of the switches. A "1" bit value means the switch is open,
//and a "0" bit means the switch is pressed.
SW_STATE read_switches(void)
SW_STATE switch_values;
switch_values = 0xFF; //Init all switch values to "open" (ie not pressed)
switch_values.rec = input(ENTER_SWITCH_PIN);
switch_values.up = input(RT_SWITCH_PIN);
switch_values.down = input(LT_SWITCH_PIN);
return(switch_values);
//This task handles debouncing, auto-repeat, and the switch event flags.
//This task is called every 10 ms. The following events are stored in
//a separate global state variable for each button.
//Key Up (Duration -- 1 or more Ticks)
//Key Pressed (Duration -- 1 Tick)
//Key Down (Duration -- 1 or more Ticks)
//Key Held Down (Duration -- 1 or more Ticks)
//Key Released (Duration -- 1 Tick)
//Key Up (Duration -- 1 or more Ticks) (Back to idle state)
//When the program starts, the button state will be initialized to "UP".
void update_switch_status(void)
SW_STATE current_switch_status;
//Read the switches.
current_switch_status = read_switches();
//Handle the "ENTER" button.
//If the switch is closed, then increment a counter. Based on the
//value of the counter, set the switch status byte to "Pressed",
//"Down", or "Held Down".
if(current_switch_status.rec == SW_CLOSED)
if(gc_ENTER_button_counter != 0xFF) //Limit count to 0xFF max
gc_ENTER_button_counter++; // because it's a byte variable
//Set the state, based on value of the down counter.
//The down counter will be a value from 1 to 0xFF.
if(gc_ENTER_button_counter == 1)
gc_ENTER_button_state = SW_PRESSED;
CBFlag = true; //MB
if(gc_ENTER_button_counter < UP_DOWN_SW_HELD_DOWN_DELAY)
gc_ENTER_button_state = SW_DOWN;
gc_ENTER_button_state = SW_HELD;
else //If the switch is open:
if(gc_ENTER_button_counter) //Has the rec sw. been down previously ?
gc_ENTER_button_state = SW_RELEASED; //If so, show it is now released
gc_ENTER_button_state = SW_UP; //If not, it's been up for at least 2+ ticks
gc_ENTER_button_counter = 0; //Always clear down ctr if switch is up.
//Handle the "RIGHT" button.
if(current_switch_status.up == SW_CLOSED)
if(gc_rt_button_counter != 0xFF) //Limit count to 0xFF max
gc_rt_button_counter++; // because it's a byte variable
//It's called a "down counter" because it counts the number of 10 ms
//"ticks" that the button has been held down continuously.
if(gc_rt_button_counter == 1)
gc_rt_button_state = SW_PRESSED;
if(value < 99)
value++; //LB
else if(gc_rt_button_counter < UP_DOWN_SW_HELD_DOWN_DELAY)
gc_rt_button_state = SW_DOWN;
gc_rt_button_state = SW_HELD;
//Check if auto-repeat should be enabled.
if(gc_rt_button_counter == UP_DOWN_SW_AUTO_REPEAT_DELAY)
gc_rt_button_auto_repeat_flag = TRUE;
gc_rt_button_auto_repeat_counter = 0;
//Check if we're in auto-repeat mode. If so, check if it's
//time to issue a "pressed" state.
if(gc_rt_button_auto_repeat_flag)
gc_rt_button_auto_repeat_counter++;
if(gc_rt_button_auto_repeat_counter == UP_DOWN_SW_AUTO_REPEAT_INTERVAL)
if(value < 99)
value++;
if(gc_rt_button_counter)
gc_rt_button_state = SW_RELEASED; //Indicate if it was just released
gc_rt_button_state = SW_UP; //Otherwise, it's been up for 2+ ticks
gc_rt_button_auto_repeat_flag = FALSE;
gc_rt_button_counter = 0; //Always clear down ctr if switch is up.
//Handle the "LEFT" button.
if(current_switch_status.down == SW_CLOSED)
if(gc_lt_button_counter != 0xFF) //Limit count to 0xFF max
gc_lt_button_counter++; // because it's a byte variable
if(gc_lt_button_counter == 1)
if(value > value_min)
value--;
gc_lt_button_state = SW_PRESSED;
else if(gc_lt_button_counter < UP_DOWN_SW_HELD_DOWN_DELAY)
gc_lt_button_state = SW_DOWN;
gc_lt_button_state = SW_HELD;
if(gc_lt_button_counter == UP_DOWN_SW_AUTO_REPEAT_DELAY)
gc_lt_button_auto_repeat_flag = TRUE;
gc_lt_button_auto_repeat_counter = 0;
if(gc_lt_button_auto_repeat_flag)
gc_lt_button_auto_repeat_counter++;
if(gc_lt_button_auto_repeat_counter == UP_DOWN_SW_AUTO_REPEAT_INTERVAL)
if(value > 0)
value--;
if(gc_lt_button_counter)
gc_lt_button_state = SW_RELEASED; //Indicate if it was just released
gc_lt_button_state = SW_UP; //Otherwise, it's been up for 2+ ticks
gc_lt_button_auto_repeat_flag = FALSE;
gc_lt_button_counter = 0; //Always clear down ctr if switch is up.
gc_button_status_updated = TRUE;
gc_old_switch_status = current_switch_status;
switch.h
//switch.h
//These are the delay periods (in 10 ms "ticks") for switch events.
//These values are used in the check_switches() function.
#define UP_DOWN_SW_AUTO_REPEAT_DELAY 25 //25 x 10ms = 250 ms
#define UP_DOWN_SW_AUTO_REPEAT_INTERVAL 10 //10 x 10ms = 100 ms = 10/sec
//These two lines specify the amount of time (in units of 10ms ticks)
//that a switch must be continuously held down, in order to be
//detected as "held down".
#define UP_DOWN_SW_HELD_DOWN_DELAY 100 // 200 x 10ms = 2 sec
//Logic levels for the switches.
#define SW_CLOSED 0
#define SW_OPEN 1
//The switch states are ordered 1 to 5 because we will clear the
//state variable to 0 in the user code to show that it has been read.
enum sw_states {SW_UP=1, SW_PRESSED, SW_DOWN, SW_HELD, SW_RELEASED};
// 1 2 3 4 5
//This structure holds the state of the switches after they are read
//from the i/o port.
typedef struct
int1 rec;
int1 up;
int1 down;
}SW_STATE;
//These enum values provide names for the indices into the array of
//gat_sw_info structures, below, instead of just using 0, 1, 2, 3, 4, 5.
enum switches {FREQ_ENTER_SW, FREQ_UP_SW, FREQ_DOWN_SW};
struct
int8 state; //This is UP, PRESSED, DOWN, HELD, or RELEASED
int8 counter; //Number of ticks that the switch has been held down.
int8 auto_repeat_counter; //When in auto-repeat, this counts off the interval.
int8 auto_repeat_flag;
}gat_sw_info[] =
{0, 0, 0, 0}, //FREQ_ENTER_SW
{0, 0, 0, 0}, //FREQ_UP_SW
{0, 0, 0, 0} //FREQ_DOWN_SW
//This variable is used in the check_switches() function.
SW_STATE gc_old_switch_status = {SW_OPEN, SW_OPEN, SW_OPEN};
//Use macros to create easy-to-read names for the switch events.
#define gc_ENTER_button_counter gat_sw_info[FREQ_ENTER_SW].counter
#define gc_ENTER_button_state (gat_sw_info[FREQ_ENTER_SW].state)
#define gc_ENTER_button_auto_repeat_counter (gat_sw_info[FREQ_ENTER_SW].auto_repeat_counter)
#define gc_ENTER_button_auto_repeat_flag (gat_sw_info[FREQ_ENTER_SW].auto_repeat_flag)
#define gc_rt_button_counter gat_sw_info[FREQ_UP_SW].counter
#define gc_rt_button_state (gat_sw_info[FREQ_UP_SW].state)
#define gc_rt_button_auto_repeat_counter (gat_sw_info[FREQ_UP_SW].auto_repeat_counter)
#define gc_rt_button_auto_repeat_flag (gat_sw_info[FREQ_UP_SW].auto_repeat_flag)
#define gc_lt_button_counter gat_sw_info[FREQ_DOWN_SW].counter
#define gc_lt_button_state (gat_sw_info[FREQ_DOWN_SW].state)
#define gc_lt_button_auto_repeat_counter (gat_sw_info[FREQ_DOWN_SW].auto_repeat_counter)
#define gc_lt_button_auto_repeat_flag (gat_sw_info[FREQ_DOWN_SW].auto_repeat_flag)
//Short named versions of the button state variables
#define ENTER_button (gat_sw_info[FREQ_ENTER_SW].state)
#define rt_button (gat_sw_info[FREQ_UP_SW].state)
#define lt_button (gat_sw_info[FREQ_DOWN_SW].state)
#define all_buttons_up ((up_button == SW_UP) && (down_button == SW_UP) && (ENTER_button == SW_UP))
#define any_button_pressed ((up_button == SW_PRESSED) || (down_button == SW_PRESSED) || (ENTER_button == SW_PRESSED))
int8 gc_button_status_updated = false;
SW_STATE read_switches(void);
Any help would be much appreciated
Brian |
Posted: Mon Feb 04, 2019 12:44 pm |
Get rid of your goto.
Goto can cause problems, since it does not ensure the stack is
correctly balanced. May well be your problem.
Simply 'break' from the loop. |
BLL
Posted: Mon Feb 04, 2019 2:09 pm |
Hi Ttelmah
I removed the goto, only there in desperation, but still the problem persists!
Brian |
Posted: Mon Feb 04, 2019 3:00 pm |
and what clears the button state?.
Nothing.
It is still going to be 'SW_PRESSED' when you exit the loop.... |
BLL
Posted: Mon Feb 04, 2019 4:10 pm |
AH...
I better find out out how to clear the button states.
Brian |
BLL
Posted: Mon Feb 04, 2019 4:18 pm |
I used the read_switches() function to clear the buttons, but it makes not one jot of difference!
Brian |
Mike Walne
Posted: Tue Feb 05, 2019 12:08 pm |
Simplify, simplify, simplify.
You say your problem is with the three switches and their three functions, one of which includes a for(;;) loop.
Reduce your program to the minimum which includes all of the above and nothing else.
I.e. three buttons and three LEDS (one for each function).
Centre and right-hand button toggle their LED, the for(;;) loop flashes its LED several times when you press left hand button.
Get rid of everything which is not needed, UART, RTC LCD etc. That way you can more easily see what's going on.
I've got no intention of wading through pages of code to get to the bottom of this one.
Mike |
