That's a Microchip issue. Can be caused by several things. For instance a
copy of explorer (or anything else), having a Window open pointing at
something in the dist/default/production tree.
Some anti-virus programs can also trigger it.
Also make sure the Project file locations are all set to places where you
do have permissions.
bazooka_ent
Posted: Sun Nov 11, 2018 1:33 pm
Hi thanks for the reply!!
Turns out this was a windows permission issue for MPLAB X.
MPLAB X shortcut needs to be "Run as Admisitrator" for the make files to create/move files around.
You can also set to run permanently as administrator by...
1) Right clicking the MPLAB X desktop short cut
2) Click -> Properties(bottom)
3) Click -> Advanced..
4) Click check box for "Run as administrator'
Cheers!!
Posted: Mon Nov 12, 2018 12:50 am
So the permissions you (as a user) had were not set to allow full access to the locations involved.
