JAM2014
Posted: Wed Oct 31, 2018 9:57 am |
Hi All,
I tested this issue with PCH 5.051, and 5.081, with no changes noted. On power up, I don't see anything on the scope at 0%, I see 25%, 50%, and 75%, but the trace remains unchanged from 75% when it's supposed to be 100%. So, 0% & 100% aren't working correctly with my hardware.
Long shot, but could this be related to using the PLL3X & CPUDIV3 fuses? That seems to be the only difference between my hardware configuration, and other hardware running the same code which IS working??
Thanks,
Jack |
Posted: Wed Oct 31, 2018 11:08 am |
I'm querying the scope setup. Remember a scope set to the default 'auto' trigger, won't trigger on a stationary signal. If set to trigger on the falling edge, it wouldn't trigger and would just stay displaying the last signal seen. The 75% duty cycle waveform.... |
JAM2014
Posted: Wed Oct 31, 2018 1:25 pm |
Hi All,
OK, well this is embarrassing! I went back again and carefully viewed the PWM output on the scope to be sure that the trigger level settings would allow me to capture everything I thought I should be capturing, and in fact it really IS working! All three versions 5.050, 5.051, and 5.081.....
Pardon me now while I go bang my head on the wall for a while!
Anyway, thanks to all for the help and guidance on this matter!!
Jack |
Joined: 01 Jul 2010 Posts: 9100 Location: Greensville,Ontario
Posted: Wed Oct 31, 2018 2:35 pm |
Look on the bright side , you FOUND the problem AND FIXED it !! That's TWO gold stars you earned today.
And...
you'll probably never make that mistake again
That's worth a silver star.
PS.. welcome to the 'club'.... |
Posted: Wed Oct 31, 2018 2:50 pm |
There are several of the posters here who are probably having memories of doing the same.....
That's why I raised the question. Been there. |
