CCS Load missing target chip? PIC24FJ1024GB606
webgiorgio
PostPosted: Mon Oct 15, 2018 7:33 am     Reply with quote
The documentation says that PIC24FJ1024GB606 is supported by the ICD-U64, but I can't find it in the list of the "select target chip" of CCS Load 5.049. Why? I don't see any 1024 kB chips.
http://www.ccsinfo.com/devices.php?page=icddevices
The hex file was made with MPLAB XC16.
At page 3 of the datasheet http://ww1.microchip.com/downloads/en/DeviceDoc/30010074e.pdf
we can see the part number of devices belongings to the same family.
Can I pick any "similar" device? rally? even with a much smaller memory?
PostPosted: Mon Oct 15, 2018 7:48 am     Reply with quote
I've just plugged on my ICD-U64, with software 5.049, and firmware 3.29, and it merrily offered me this chip. Then updated (the software is now up to 5.051, and firmware on 3.32), and the chip is still there.
No you can't use the wrong device. The ID is checked when programming, but you should not have to. The unit supports the chip.
There are only 4 1024K chips listed. Last four entries above the 30F1010. You are probably just missing them in the list. it is a long list!...
webgiorgio
PostPosted: Mon Oct 15, 2018 9:12 am     Reply with quote
Thanks Ttelmah for the test.
I checked again, here is a screenshoot of my list. I have a 512 kB part above the 30F1010. https://drive.google.com/open?id=1PxOrA6V5TNNIUbd0vxuukurzu0oo-9SX
I have firmware 3.01.
PostPosted: Mon Oct 15, 2018 10:20 am     Reply with quote
Honestly the answer is probably the firmware. 3.01, is very old. I had to update to about 3.15, to get support for several chips, and given that with 3.29, and 3.32 it offers the chip you want, I'd be updating.
webgiorgio
PostPosted: Tue Oct 16, 2018 12:01 am     Reply with quote
Still does not show up after updating everything to latest versions.
I don't see any part with more than 512 kB. Could it be that my programmer is old and does not have enough memory to program a 1024 kB PIC?
Software: 5.051
Firmware: 3.32
Hardware: Rev 2 (Pid 194) <-- how does it compare with yours?
PostPosted: Tue Oct 16, 2018 7:24 am     Reply with quote
Ah Rev2....
There are a lot more chips that actually require Rev3, than the list says. Suspect this is the problem. :(
Mine is Rev3.
Ask CCS. A couple of nearby chips do say '3' (which is the 'requires Rev3') indicator.
webgiorgio
PostPosted: Thu Oct 18, 2018 2:25 am     Reply with quote
Solved. Laughing
The CCS support told me to search for devices5p.dat to be a recent file, like months. I found one file from 2014 in the PICC folder (devices.dat).
I installed the free version of CCSLOAD in a different folder than PICC, and there I found a recent devices5p.dat.
I run the ccsload.exe from the new installation, and the device of my interest shows up in the list.
I copied the new devices5p.dat in the old folder renaming it to the old name but that does not fix the ccsload that came with the compiler.
PostPosted: Thu Oct 18, 2018 12:26 pm     Reply with quote
CCSload is always free. There is not a charge for version. Why aren't you just installing the new version on top the same location where it is already installed?.
PostPosted: Thu Oct 18, 2018 12:36 pm     Reply with quote
http://www.ccsinfo.com/downloads/setup_ccsload5.exe
PostPosted: Thu Oct 18, 2018 1:19 pm     Reply with quote
Or just let the original version update itself.
Start the program.
Select the diagnostics tab.
Select update from web.
