srikrishna
Difference between PORT and PIN |
Posted: Wed Jun 06, 2018 1:48 pm |
What is the difference between PORT and PIN?? Are they same??
I have searched in the internet but did not get satisfactory answer.
Posted: Wed Jun 06, 2018 1:56 pm |
You are asking questions about Atmel microcontrollers. That's off topic on
the CCS forum.
Use Google and search for this:
Quote: | atmel ddra porta pina |
srikrishna
Posted: Wed Jun 06, 2018 2:14 pm |
PCM programmer wrote: | You are asking questions about Atmel microcontrollers. That's off topic on
the CCS forum.
Are they same for PIC ??? |
Joined: 01 Jul 2010 Posts: 9096 Location: Greensville,Ontario
Posted: Wed Jun 06, 2018 2:25 pm |
PORT is typically a collection of I/O pins that can be accessed at one time. PORTs can be 1 bit wide, 4 bit wide, 8 bit wide, 16 bit wide or more (or less) depending on the device being used (and the 'mode').
PIN generally means a single 'pin', which can be Input/Output, input only or output only. |
srikrishna
Posted: Wed Jun 06, 2018 2:28 pm |
Thanks |
