PIC C compiler config bits set/reset option dspic30f4011
Hassan
PostPosted: Mon Apr 30, 2018 3:10 pm     Reply with quote
Hello
I am using PIC C compiler. I am using a dspic30f4011 Microcontroller.
I want to ask if I could set/reset configuration bits of a specific module/function register??? or I am bound to use predefined functions in PIC C??
e.g.
T1CONbits.TON = 0; // Turn off timer 1
T1CONbits.TSIDL = 0; // Continue operation during sleep
T1CONbits.TGATE = 0; // Gated timer accumulation disabled
T1CONbits.TCS = 0; // use Tcy as source clock
T1CONbits.TCKPS = 0; // Tcy / 1 as input clock
Can I do this in PIC C????
PostPosted: Mon Apr 30, 2018 6:15 pm     Reply with quote
Unless the PIC is relatively new, the compiler features built-in functions that do this sort of thing for you. In your example,
setup_timer1()
would probably do it.
Download the compiler manual and thumb through it to get an idea of what it can do:
http://www.ccsinfo.com/downloads.php#manuals
PostPosted: Mon Apr 30, 2018 7:13 pm     Reply with quote
I want to ask if I could set/reset configuration bits of a specific module/function register ?
The answer is yes, if want to, you can do it that way.
The IDE version of the CCS compiler can generate a header file like this:
http://www.ccsinfo.com/forum/viewtopic.php?t=46210
I assume you want this because you're translating code to CCS from
another compiler, and it sets the bits to configure peripherals.
See this thread for instructions on how to generate the header file:
http://www.ccsinfo.com/forum/viewtopic.php?t=52602
