how to send address and Hexadecimal value use UART
harizal
PostPosted: Fri Apr 13, 2018 6:59 pm     Reply with quote
how to convert this code from hi-Tech C to CCS C Compiler:
i use MP14A (multiPWM) connected to PIC16F877A.
This Coding from Hi-Tech to activate the MultiPWM use UART:
send_serial(0x01); // send channel of PWM to activate PWM1
send_serial(0x7f); //send PWM value.PWM value for PWM1 is 127
send_serial(0x02); // send channel of PWM to activate PWM2
send_serial(0xff); //send PWM value.PWM value for PWM1 is 255
When i code in CCS C compiler like this it not working at all:
printf("%X",0x01); // Channel PWM1
printf("%X",0xFF); //Value of PWM
PostPosted: Fri Apr 13, 2018 7:40 pm     Reply with quote
Use putc(). It should work. Example:
putc(0x01); // send channel of PWM to activate PWM1
putc(0x7F); // send PWM value.PWM value for PWM1 is 127
putc(0x02); // send channel of PWM to activate PWM2
putc(0xFF); // send PWM value.PWM value for PWM1 is 255
Also, you don't have to use hex. You can just use the numbers. Example:
putc(1);   // Ch. 1
putc(127); // PWM value
putc(2);   // Ch. 2
putc(255); // PMW value
Here is the user's manual for the Cytron MP14A Multi-PWM chip (14-channels):
http://synacorp.my/v2/en/index.php?controller=attachment&id_attachment=267
PostPosted: Fri Apr 13, 2018 11:36 pm     Reply with quote
It's perhaps worth explaining 'why'.
Putc sends the single character. putc(0x1); sends the binary character '1' on the serial.
This sends the value 1, encoded as an ASCII character. So the binary value 0x31.
