jjabi
timer0 interrupt function takes 4ms? |
Posted: Sat Mar 24, 2018 7:23 am |
Hi, im new here and fairly new to PIC microcontrollers.
I am trying to set up a 10ms interrupt on timer0 on 31kHz internal oscillator frequency, and have almost succeeded. I am using PIC16LF1574.
I'm testing the code on Proteus 8 simulator and also on breadboard. I am trying to get a LED to blink 10sec ON 10sec OFF. Just a simple test program.
Well I set all the timer stuff properly like this:
Timer0 clock is 31kHz so instruction clock is 31/4 = 7.75kHz so one period is 129.032 us.
When prescaler is 1, one count takes129 us when INTERRUPT using 8-bit timer comes every: 129.032 us * 256 = 33 032 us = 33 ms.
To get it to be 10 ms: 129.032 us counts fit into 10ms is: 10 000 / 129.032 = 77.5 so we have to skip 256 - 77.5 = 178.5 = 179 counts.
Code: | #include <16LF1574.h>
#device ADC=10
#fuses INTRC_IO,NOWDT,PROTECT,NOBROWNOUT,NOPUT,NOWRT,NOMCLR
#use delay(clock=31000)
int16 increment = 0;
//Interrupt called when TMR0
//flips from 255 to 0
//Timerin pitäisi interruptaa kerran 10 ms
#int_TIMER0
void clock_isr()
output_high(PIN_C3); //for the oscilloscope simulation
increment++;
set_timer0(179);
setup_oscillator(OSC_31kHZ);
setup_timer_0( T0_INTERNAL | T0_DIV_1 );
enable_interrupts( INT_TIMER0 );
enable_interrupts( GLOBAL );
set_timer0(179); //pyörähtää kun 256
output_low(PIN_C3);
if (increment > 1000)
output_high(PIN_C4);
if (increment > 2000)
output_low(PIN_C4);
increment = 0;
NOW the problem is that the led blinks in every 14 secs instead of 10secs. I investigated this using Proteus 8 oscilloscope, and I noticed that the program takes 4ms in the interrupt function. So every interrupt takes 14ms to get through instead of 10ms. Any idea why is this happening and how to fix this?
Thanks! |
alan
Joined: 12 Nov 2012 Posts: 349 Location: South Africa
Posted: Sat Mar 24, 2018 7:32 am |
You realize that it takes 130us per instruction with your 31kHz clock. So 4ms gives a total of 30 instructions. About what it takes to get in/out of interrupt with say 7 instructions in interrupt.
Regards |
jjabi
Posted: Sat Mar 24, 2018 7:35 am |
alan wrote: | You realize that it takes 130us per instruction with your 31kHz clock. So 4ms gives a total of 30 instructions. About what it takes to get in/out of interrupt with say 7 instructions in interrupt.
Regards |
Oh I see, but I only have 3 instructions in my interrupt though? So I should try raising my frequency. The reason I wanted to use 31kHz to save power as much as possible in my design I'm making. I have it working in 4MHz at the moment perfectly, it just takes 0.5mA more current. |
Posted: Sat Mar 24, 2018 7:53 am |
hmm saving power implies a battery operated device.
if so , check out an application note on Microchips website involving calculating power used. Simple hardware a small PIC, an ADC chip and sending data to a PC. There's LOTS of interesting info in the apnote and going slower is NOT necessarily going to save energy !
I don't have the appnote #, though an667 (?) rings a bell as well my Microchip books are at the office and I'm not. It shouldn't be too hard to find though, look for an appnote from about 15 years ago.
These days using a higher capacity battery only costs pennies compared to back then.
And
As alan said there is a LOT of 'overhead' code in doing ISRs. Dump the listing of your program and you'll see it all.
jjabi
Posted: Sat Mar 24, 2018 8:39 am |
I measured the current in my design to be about 3mA when using 4MHz clock, and around 2.5mA when using 31kHz clock. While it is not much of a difference I thought it would be a nice plus if I got it to work.
So now that I adjusted the blink to interrupt count (around 700 and 1400) according to 14ms interrupt cycle I got it blinking in 10sec ON/OFF. But it becomes too complex so perhaps it is best to just raise the frequency for now.
Posted: Sat Mar 24, 2018 11:20 am |
jjabi wrote: | alan wrote: | You realize that it takes 130us per instruction with your 31kHz clock. So 4ms gives a total of 30 instructions. About what it takes to get in/out of interrupt with say 7 instructions in interrupt.
Regards |
Don't confuse C instructions with machine instructions.
A single C instruction, like *, can involve a thousand or more machine instructions.
In your case, not this bad, but each C instruction is several machine instructions.
When you think it is doing over 100 times more per second at 4MHz than 30KHz, it is actually much more efficient to clock faster. There is usually an 'optimum speed' where the processor does the most per uW. Typically around 1 to 4Mhz. |
Posted: Sat Mar 24, 2018 5:09 pm |
OK, it took me awhile but I FINALLY found the appnote...
It's AN606, circa 1997, and should be a must read for anyone doing battery powered devices.
Yes, it's old, same age as my pickup, BUT it's a great resource.
Still available from the Microchip website.
Mike Walne
Posted: Sun Mar 25, 2018 4:37 am |
Simply increasing the value you use for this line (from ISR) will allow you decrease the on/off periods from 14s to 10s.
I'll let you work out what the value needs to be.
The down side is that if (when) you edit your ISR you may have to change the value used.
A better approach is to increase the timer0 value rather than set it to a fixed one.
Like Mr T says, read the AP note. You may find a reason why there is so little difference in current when you go from 31kHz to 4MHz.
Mike |
Posted: Sun Mar 25, 2018 11:38 am |
I think were going to have to start answering to the "two T's"...
Half of the comments come from Jay (Temtronic), and the rest from me.
Nice is that we are both singing from the same sheet (maybe the "Two T's" could be a group.....). |
jjabi
Posted: Tue Mar 27, 2018 6:46 am |
Thanks for your help guys!
I will read the appnote thank you for this.
Quote: | The down side is that if (when) you edit your ISR you may have to change the value used.
A better approach is to increase the timer0 value rather than set it to a fixed one. |
I'll look into this also. |
