art
shift right/left using Flex_LCD420.c |
Posted: Mon Mar 12, 2018 2:28 am |
I would like to shift right/left "Hello to the world" using Flex_LCD420.c .
However, it will display the same thing in line 1 and line 3 while line 2 will be same with line 4. I just want it to display in line 1 and 2 only.
What is wrong with below code ? Please help me.
#include <18F4550.H>
#include "Flex_LCD420.c "
void lcd_scroll_right(void)
lcd_send_byte(0, 0x1E);
void lcd_scroll_left(void)
lcd_send_byte(0, 0x18);
int8 i;
lcd_putc("\f"); // Clear the LCD
lcd_putc("Hello to the Side scrolling \n");
lcd_putc("world. demo. ");
for(i = 0; i < 20; i++)
lcd_scroll_left();
delay_ms(200);
delay_ms(2000);
Posted: Mon Mar 12, 2018 4:51 am |
You need to look at your LCD module's datasheet and see the 'memory map' for the addresses of the 'data display RAM' to see why it is happening.
You should see that line 3 is after line 1 and that the '21st' character of line 3 'wraps' around to line 1, character 1. The same operation happens with line 4 and 2.
Your scrolling function needs to have limits set in it. What I've done in the past is have a 2nd 'display buffer' of 20 bytes long. I scrolled the data within THAT buffer, then simply sent the buffer to the LCD. This doesn't use the LCD internal command of 'shift', you're in control.
You may find 'scrolling' code here (just try the 'search' button up top), if not Goggle will, something like 'LCD module scrolling' should limit the hits to less than a million...
