Flag bit definition question
pyrodigy
PostPosted: Wed Jan 24, 2018 5:58 pm     Reply with quote
Hello All,
I am new to ccs and this is my first topic in here. First of all i would like to say something that i have been following this forum for a while and would like to Thank you guys. I have found out lots of things, learned more than many books thanks to all of you. i am very happy to be here.
Now i am a little bit confused abouth bit definition between the following definitions examples,
Def.Example -1
unsigned   int16 AdresFlags; //Flag Bits
#bit  Adres1 = AdresFlags.0
#bit  Adres2 = AdresFlags.1
#bit  Adres3 = AdresFlags.2
#bit  Adres4 = AdresFlags.3
#bit  Adres5 = AdresFlags.4
#bit  Adres6 = AdresFlags.5
#bit  Adres7 = AdresFlags.6
#bit  Adres8 = AdresFlags.7
#bit  Adres9 = AdresFlags.8
#bit  Adres10 = AdresFlags.9
And
Def.Example - 2
struct {
unsigned   int8 Adres1:1;
unsigned   int8 Adres2:1;
unsigned   int8 Adres3:1;
unsigned   int8 Adres4:1;
unsigned   int8 Adres5:1;
unsigned   int8 Adres6:1;
unsigned   int8 Adres7:1;
unsigned   int8 Adres8:1;
unsigned   int8 Adres9:1;
unsigned   int8 Adres10:1;
}AdresFlags={0,0}; // Flag Bits
Could you please let me know what is main difference between these definition examples?
What compiler behave whenever it see these definitions ?
and also
I am currently having a problem for the following operation. Whenever i use definition example-1 everything looks OK. but whenever i defined as example-2 i am having an '' A numeric expression must appear here '' Error.
Why ? Where am i wrong ?
void TEST(void)
static unsigned int16 ADRESDATA_READ=0;  // ADRESS BUTON DATA
        // HERE READ 10 BIT FROM SERIAL PORT
         AdresFlags ^= ADRESDATA_READ;    //  TOGGLE FLAG BITS (OR OPERATOR)
Note: PIC16F1526
CCS VERSION=5.074
Best Regards Smile
PostPosted: Wed Jan 24, 2018 6:27 pm     Reply with quote
You should post a complete test program so we don't have to do any work
to make one. Then we can just copy and paste it into our IDE and test it.
I made one below.
I was able to make it compile by casting AdresFlags to an int16 as shown
below:
#include <16F1526.h>
#fuses INTRC_IO, NOWDT
#use delay(clock=4M)
struct {
void TEST(void)
(int16)AdresFlags ^= ADRESDATA_READ;    // *** cast to int16
TEST();
while(TRUE);
PostPosted: Thu Jan 25, 2018 2:00 am     Reply with quote
In terms of differences, none really....
'Bit fields' (the : syntax), is standard C. Advantage comes where you are perhaps wanting to work with several bits together. So (for instance), the register AD1CON1 on a PIC24, can be defined like:
struct __attribute__((packed)) {
   uint done:1;
   uint samp:1;
   uint asam:1;
   uint na:1;
   uint ssrc:4;
   uint form:2;
   uint mode12:1;
   uint dmaen:1;
   uint dmabm:1;
   uint adsidl:1;
   uint na1:1;
   uint adon:1;
} AD1CON1;
And you can talk to AD1CON1.ssrc, as an entity occupying 4 bits.
For single bit use no real difference.
However the #BIT directive, was specifically an optimisation. The PIC itself has a single instruction bit set/clear operation, and the #bit directive automatically accesses this. It was a way to offer the programmer access to this specific machine instruction. There are other (swap for example).
That being said, the current optimiser is quite smart, and for a single bit access into the bit fields form, will substitute the optimised machine instruction.
Remember if using bit fields, that you have to think what order the processor actually allocates bits, and (for the PIC 12/16/18), the 'wrapper' type is a single int8 only - hence the two byte initialisation you show, while with the #bit directive, you can initialise the larger type.
The problem you are having with bitfields, is that with this 'AdresFlags', is not an int16. It is a structure containing the bits. What you have to do is tell the compiler to treat this structure 'as' an int16. This is what PCM_Programmer is showing (the cast is the vital thing here).
You can also take advantage of a union here:
struct bits {
}; // Flag Bits
union {
    struct bits b;
    unsigned int16 whole;
} AdresFlags;
    //You can then talk to single bits:
    AdresFlags.b.Adres9 =1; //for example
    //Or the whole word as
    AdresFlags.whole ^= ADRESDATA_READ;
pyrodigy
PostPosted: Thu Jan 25, 2018 4:04 am     Reply with quote
I made one below.
My main program contains 68 push button and 100 led indicator over spi, 2 x usart, i2c, lcd...ext so in my opinion if i post complete program it will be hard to focus main question. I only say my main flow control related to these Flag bits test.
About the test functions;
I defined a dummy test program, i test the codes where i stuck and look at the mplab simulator to see what is going on.
This test dedicated to bit definitions to understand difference between bit definitions.
void TEST(void)
static unsigned int16    ADRESDATA_READ=0; //ADRESS BUTTON DATA READ from 2 x 165
   while(TRUE){
         read_ADRES_inputs(&ADRESDATA_READ); // READ 10 Bit from 2 x 74HC165
                                 // same function as read_expanded_inputs() in 74165.c driver
         ADRESDATA_READ = ADRESDATA_READ & 0x3FF; // MASK High 6 bits (00000011 111111111)
         if(ADRESDATA_READ)  //Zero Test
            if(MultiCue)   //If MC button pressed
            AdresFlags ^= ADRESDATA_READ; //Toogle bits
            else         //If Not
            AdresFlags = ADRESDATA_READ; // assign whole
My main aim is, as i stated in my previous i am not getting error when i defined as #BYTE and its Flag #bits method. I just would like to know struct type bit definition method. C programming language book explained shallow for the struct type bit definitions.
Thank you for your code, i am glad to see CCS sort out easily with redefine as 16 bit (int16) AdresFlags register.
   uint done:1;
   uint samp:1;
   uint asam:1;
   uint na:1;
   uint ssrc:4;
   uint form:2;
   uint mode12:1;
   uint dmaen:1;
   uint dmabm:1;
   uint adsidl:1;
   uint na1:1;
   uint adon:1;
} AD1CON1;
struct bits {
}; // Flag Bits
union {
    struct bits b;
} AdresFlags;
Honestly this is the exactly answer what i am looking for. Your lesson should be the duration of the bit-fields topic in the Dennis Ritchie's book Smile
I will read again and again Thank you very much. I appreciated.
