SINE INVERTER
phamkien
SINE INVERTER
PostPosted: Sun Jan 21, 2018 11:55 pm     Reply with quote
Hi Everyone!
I'm writting a code to make a sine wave inverter using pic 16f684. Please kindly give me some advices. I had wrote the code as below:
At first, PIN_C5 ( CCP1) will be used for creating spwm signal.
and the two square wave signal ( 50Hz ). I will use Pin C0 and Pin C1.
When I try to simulate on Proteus. I saw the delay time like the attached picture.
[img]https://photos.app.goo.gl/erggeFTNOxMV7Jru1[/img]
what I need is: Square wave signal turn on at the same time with Spwm signal and turn off when it finish a half Sine wave.
May I know which one will be used for control Spwm. Is it TMR2 ?
When I read the net, they wrote: TMR2 will increase from 0 to PR2. When TMR2=PR2, timer 2 interrupt is enabled.
I had tried the below code but it didn't work as expected.
If(TMR2==0) { output_high(pin_c0); output_low(pin_c1); }....
Please kindly give me an advice. Thank you!
PostPosted: Mon Jan 22, 2018 3:04 am     Reply with quote
Problem is that assuming the loop doing the testing is doing anything else, it can very easily miss TMR2 being actual being equal to 0....
Now you say TMR2 interrupt is enabled. Do you have an interrupt handler?.
You must never enable an interrupt without a handler.
However assuming you do just want to test for the moment when TMR2 passes it's top count, and goes back to zero, then you don't actually want to enable the interrupt....
    //before you start waiting
    disable_interrupts(INT_TIMER2);
    clear_interrupt(INT_TIMER2);
    //Now your loop whatever it involves 'xxx'
    while (xxx)
        if (interrupt_active(INT_TIMER2))
             //whetever you have to do when the timer has wrapped
             output_high(pin_c0); output_low(pin_c1); //etc.
             clear_interrupts(INT_TIMER2);
        //other stuff in the loop
Key thing is to understand, that the interrupt will set (and you can clear it), even if it is _not_ enabled. What 'enabling' does, is says that this interrupt can call a handler. Once this is set, the interrupt _will_ call a handler (so the handler must be present), if the global interrupt flag is also set.
If you are using an interrupt handler, then if you want this code outside, instead of testing for TMR2==0, set a flag in the interrupt handler and test for this (again like the interrupt clear it once used).
phamkien
PostPosted: Mon Jan 22, 2018 9:47 pm     Reply with quote
Dear Mr Ttelmah
Thank you for your help. Can you please help me one more time? Refer to your instruction, I had wrote a code as below but it still doesn't work properly. Here is my code.
   char duty_cycle[41]={0, 15, 31, 46, 60, 75, 89, 102, 115,
   127, 139, 149, 159, 168, 176, 183, 188, 193, 196, 199, 200, 200, 199,
   196, 193, 188, 183, 176, 168, 159, 149, 139, 127, 115, 102, 89, 75,
   60, 46, 31, 15};
   setup_timer_2(T2_DIV_BY_4,249,1);
   setup_ccp1(CCP_PWM);
   set_pwm1_duty(0);
   output_low(pin_c0); output_low(pin_c1);
   while(true)
               i++;
               if(i==40) {i=0; j++; if(j==2) j=0;}
         set_pwm1_duty(duty_cycle[i]);
         if(j==0) {output_high(pin_c0); output_low(pin_c1);}
         if(j==1) {output_low(pin_c0); output_high(pin_c1);}
https://photos.app.goo.gl/14XtPE2WGWJgxeBq1
Thank you!
PostPosted: Tue Jan 23, 2018 12:29 am     Reply with quote
One fundamental thing, the 'set_pwm_duty' wants to be inside the part only called when the i changes.
phamkien
PostPosted: Tue Jan 23, 2018 1:03 am     Reply with quote
Dear Mr Ttelmah
Thank you very much for your help.
Best regards!
