You just have to look for the chip data sheet (the KS0107 & 0108, which form the core of the system).
Your problem is how can the PIC ever raise the pin high enough?. Your old PIC supported operation to 5v. The new chip supports 4v _max_.... The RSTB line is four loads (it feeds all four KS0108 chips in parallel), and needs to go up to 3.5v to be seen as high.
You have a signalling voltage problem.
borseyogesh1436
Posted: Thu Jan 04, 2018 2:24 am
I don't think that's supply problem because its working with same voltage with other compiler that's working fine.
Posted: Thu Jan 04, 2018 4:36 am
Er. You talk about taking the signal to 5v. You do realise this is a 3.3v PIC?. The other PIC you talk about is rated to operate up to 5v. This one is not.
Now the data sheet for the GLCD controller chip says that the RST signal needs to go up to 3.5v to be seen as 'high'. This PIC is never going to take the signal up to 5v.Maximum operating voltage is 3.6v. It has inputs that will accept signals up to 5v, but it's outputs are 3.3v only.
borseyogesh1436
Posted: Thu Jan 04, 2018 4:46 am
Thanks for helping friends
the problem is solved,
i forget to use read = PORTD and write =LATD
with DSPIC30f6014A
code is working
void glcd_writeByte(int1 side, int8 data)
{ TRISDH=0x00;
if(side) // Choose which side to write to
output_high(GLCD_CS2);
output_high(GLCD_CS1);
output_low(GLCD_RW); // Set for writing
LATDH=data; //output_d(data); // Put the data on the port
delay_cycles(1);
output_high(GLCD_E); // Pulse the enable pin
delay_cycles(5);
output_low(GLCD_E);
output_low(GLCD_CS1); // Reset the chip select lines
output_low(GLCD_CS2);
BYTE glcd_readByte(int1 side)
int8 data; // Stores the data read from the LCD
TRISDH=0xFF; // Set port d to input
output_high(GLCD_RW); // Set for reading
delay_cycles(1);
delay_cycles(4);
data = PORTDH; // Get the data from the display's output register
output_low(GLCD_E);
return data; // Return the read data
Page 2 of 2
