borseyogesh1436
Low voltage detect on PIC18F46K22 not working |
Posted: Sat Dec 09, 2017 4:41 am |
hi friends i want to monitor power down, i found that code on ccs forum,
HLVDIN Pin (RA5) is connected to the supply voltage
(RA3) is connected to to RE&DE of max485
but it will display only
Quote: | Start
Low Voltage Detect module didn't stabilize |
can any one solve that problem,
Code: | #include <18F46K22.h>
#device ADC=16
#use delay(crystal=7.372800MHz)
#bit LVDIF_BIT = getenv("SFR:PIR2").2
int8 lvd_flag;
#int_hlvd
void hlvd_isr(void)
lvd_flag = TRUE;
disable_interrupts(INT_HLVD);
int8 wait_for_lvd_to_stabilize(void)
int16 timeout_count;
timeout_count = 0xFFFF; // Many milliseconds
set_tris_a(0x10);
output_high(Pin_a3); //rs485 tx enable
while(timeout_count--)
if(LVDIF_BIT)
return(TRUE);
return(FALSE);
printf("Start\n\r");
setup_low_volt_detect(LVD_TRIGGER_BELOW | LVD_43);
LVDIF_BIT = 0; // Clear the LVD interrupt flag
enable_interrupts(INT_HLVD);
if(wait_for_lvd_to_stabilize() == FALSE)
printf("Low Voltage Detect module didn't stabilize\n\r");
while(1); // Wait here forever
if(lvd_flag == TRUE)
printf("\n\rLow voltage\n\r");
lvd_flag = FALSE;
printf("A");
Posted: Sat Dec 09, 2017 5:06 am |
Think about what you are doing in your initial wait.....
You are enabling the interrupt, with a handler. When the interrupt triggers, that handler is called, and the interrupt flag is then cleared. How can LVDIF_BIT ever be 'TRUE' in the main code?. The interrupt handler will always be called when it goes true...
You either need to not enable the interrupt (the flag will still set), and get rid of the interrupt handler, or test the 'lvd_flag' bit the handler sets.
I'd suspect the code you are basing on, did the former, and simply did not enable the interrupt till after the initial stabilise time. |
borseyogesh1436
[solved] Low voltage detect on PIC18F46K22 not working |
Posted: Sat Dec 09, 2017 5:31 am |
Thanks for reply Ttelmah
code is working
Quote: | Low voltage < 4.3
voltage > 4.3
Low voltage < 4.3
Low voltage < 4.3
Low voltage < 4.3
Low voltage < 4.3
Low voltage < 4.3
Low voltage < 4.3
Low voltage < 4.3
Low voltage < 4.3
Low voltage < 4.3
voltage > 4.3
voltage > 4.3
voltage > 4.3
Low voltage < 4.3
Low voltage < 4.3
Low voltage < 4.3
voltage > 4.3
Low voltage < 4.3
Low voltage < 4.3
Low voltage < 4.3
Low voltage < 4.3
Low voltage < 4.3
Low voltage < 4.3
Low voltage < 4.3
Low voltage < 4.3
voltage > 4.3
voltage > 4.3
voltage > 4.3
voltage > 4.3
voltage > 4.3
voltage > 4.3
voltage > 4.3
voltage > 4.3
voltage > 4.3
voltage > 4.3
voltage > 4.3
Low voltage < 4.3
Low voltage < 4.3 |
#device ADC=16
int8 lvd_flag;
#int_hlvd
void lvd_isr(void)
lvd_flag = TRUE;
set_tris_a(0x10);
printf("\n\rLow voltage < 4.3\n\r");
lvd_flag = FALSE;
printf("\n\r voltage > 4.3\n\r");
