ADC in PIC18F4520 - fluctuation in reading
Dean
PostPosted: Thu Dec 07, 2017 6:40 pm     Reply with quote
Hi everyone
I am using pic18F4520 ADC to read voltage which varies between 0 - 5 volts across 100 ohm resistor as a current sensor.
The reading I am gettting from the PIC fluctuated in High range while the AVOmeter reading is steady and exactly matches the calculations.
The code I am using is here:
void TreatmentLoop()
     setup_adc_ports(AN0);       //sets Only AN0 pin  to analog input
      set_adc_channel(0);        //the next read_adc call will read
       while (True)
            ReadCurrent() ;
            lcd_gotoxy(1,1);
            printf(lcd_putc "%lu \n\r", ANP1);
            lcd_putc("Current Dose ");
            delay_ms(1000) ;
Device is set as 16 bit
#device ADC=16
Reading I am getting varies between 0 to 320 (64, 128, 256, 320) in a random manner, while the reading is firmly steady on the AVOmeter. I can not understand why. Am I missing something here ????
Dean
Find a way Or Make one .
PostPosted: Thu Dec 07, 2017 7:34 pm     Reply with quote
hmm according to my datasheet, that PIC has a 10 bit ADC NOT a 16bit so I'd suggest:
#device ADC=10
The compiler should complain about it, though maybe it's smart and handles the configuration properly. Without a complete program we can't cut/paste/compile and dump the listing.
You should post your complete program as the ADC needs several options to be setup correctly.
The ADC is a single ended device. You mention a '100r load resistor' for current sensing, is one end tied to ground?
What is the actual load? If it's a motor, that will generate a LOT of EMI (noise) which the PIC's ADC will read unlike the DMM which only sample 3-4 times a second
Others will respond, these are just some quick comments I can think of.
PostPosted: Thu Dec 07, 2017 7:56 pm     Reply with quote
I don't see a line that calls the setup_adc() function.
PostPosted: Fri Dec 08, 2017 2:39 am     Reply with quote
With ADC=16 selected the ADC is switched to 'left justified'. So a single count on the ADC will be 64 on the result....
The ADC will display steps of just 5mV, and quickly. An analog meter won't even see this, while conventional DVM's integrate the reading.
Remember also that the ADC is dependant on the reference being used. If this is the supply, there will be several mV of noise on this (and more on most prototype layouts).
PostPosted: Fri Dec 08, 2017 1:03 pm     Reply with quote
The 'readcurrent()' function could be at fault. We have no idea what it actually does aside from a guess that maybe it stores something into a variable called ANP1 that main() printsout ??
PostPosted: Fri Dec 08, 2017 1:28 pm     Reply with quote
He is only seeing 5 counts on the ADC.
We haven't seen what clock rate is being used by the ADC?.
We haven't seen what reference is being used by the ADC?.
Dean
PostPosted: Fri Dec 08, 2017 4:20 pm     Reply with quote
Thank you guys Problem solved with your advises
1. Software mistake #device ADC=10 NOT 16
2. Hardware , extra capacitor is added 470Micro F at the power source
Now its working like a Swiss clock . Laughing
Dean
PostPosted: Fri Dec 08, 2017 4:40 pm     Reply with quote
Glad to hear it's 'up and running'.
Old school rule of thumb for power supplies
1) you need 1,000 MFD for every amp drawn
2) supply double the current you 'think' you need...
3) if motors or relays are involved... TRIPLE the supply !!
4) if it's 'marginal' , it will kinda fail, latch-up the product and cause you no end of grief...until you put a 10 AMP supply in...BTDT
