lz1ght
[SOLVED]printf problem with integer |
Posted: Tue Nov 28, 2017 11:09 pm |
I have a strange problem with PIC18F4520.
Compiler now is 5.047 demo, but I try first with 5.049, 5.019 and 4.???
I also try with int16, int32. Result is same.
Code: | #include <main.h>
int i=0;
for ( i = 32; i < 80; i++) {
printf ( "Char %c Dec %d Uns %u \r\n", i, i, i);
while(TRUE) { }
Results is:
Quote: | Char Dec 0 Uns 0
Char ! Dec 0 Uns 0
Char " Dec 0 Uns 0
Char # Dec 0 Uns 0
Char $ Dec 0 Uns 0
Char % Dec 0 Uns 0
Char & Dec 0 Uns 0 |
I change MCU with PIC16F877A and all is normal. Any idea?
Thanks,
Georgi.
Posted: Wed Nov 29, 2017 2:22 am |
Show us your fuses. main.h.
I'd guess something like you have XINST selected (which will cause peculiar oddities through the program). May even be selected by default. Doesn't apply with a PIC16, but does with a PIC18. So make sure you have the NOXINST fuse selected. |
lz1ght
Posted: Wed Nov 29, 2017 11:54 am |
main.h
Code: | #include <18F4520.h>
//#include <16F877A.h>
#device ADC=10
#FUSES PUT //Power Up Timer
#FUSES NOPBADEN //PORTB pins are configured as digital I/O on RESET
#use delay(crystal=18432000)
#use rs232(baud=9600,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8,STOP=1)
Now result is:
Quote: | Char Dec 1<8 Uns 1<0
Char ! Dec 1<8 Uns 1<0
Char " Dec 1<8 Uns 1<0
Char # Dec 1<8 Uns 1<0
Char $ Dec 1<8 Uns 1<0
Char % Dec 1<8 Uns 1<0
Char & Dec 1<8 Uns 1<0
lz1ght
SOLVED |
Posted: Wed Nov 29, 2017 12:05 pm |
Many Thanks Ttelmah
I use bootloader and he don't change fuses.
Now is OK. |
Posted: Wed Nov 29, 2017 12:41 pm |
The bootloader can never change fuses.
Problem is if it changes the fuses then these can stop it running.
This is why it is vital to ensure that you program the bootloader with the fuses you intend to finally use, and you then have the code you load with the bootloader without any fuses (#FUSES NONE).
Anyway at least you now know what the problem was. |
